please help
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=9749
Author:  racefreakj77 [ Thu Jun 24, 2010 1:18 am ]
Post subject:  please help
I have been trying everthing I know to try and fix my brakes but nothing is working. I even tried everything I read on the Woodsbuggy website. And KYbuggy1, I even tried your homemade pressure bleeder and I get nothing. I am coming to the hill climb in Ohio this weekend, sometime Friday afternoon.
If there is anyone that can help me try to resolve this problem I would be greaty indebted to you !
I also have brand new Neal dual handle turning brakes and peddles, and two new rear brake calipers.
I'm still willing to hear any other suggestions anyone has to offer...Thanks !
Author:  nitro_mudder [ Thu Jun 24, 2010 2:23 am ]
Post subject:  Re: please help
Resevoir new as well? I had good luck ussing a power bleeder, with the back end up on my trailer so it was putting the calipers higher then the res. Let it sit for a while if you can. Gravity will help move the air bubbles to the calipers. That is assumming there is not a place that is leaking in air. Got the diaphram in the res lid too?
Author:  racefreakj77 [ Thu Jun 24, 2010 3:06 am ]
all new but the lines. no leaks that i could find. i have tryed everything with no luck... im hoping someone will help me friday after noon when we get to ohio. i would pay for help so i can play this weekend.
Author:  bruce 1 [ Thu Jun 24, 2010 6:35 am ]
Come on I will help. Bring your power bleeder.
Author:  kybuggy1 [ Thu Jun 24, 2010 6:45 am ]
I wont be there until Fri night, but if they aint fixed by then I will do what I can. Sometimes brand new components can be bad, seen this plenty of times with m/c s. Bring your old stuff, or any spare stuff you got.
Author:  Firebug [ Thu Jun 24, 2010 6:48 am ]
If you are using old rubber hoses at the pivot points they may be clogged,, is fluid coming out freely when you bleed?
Author:  chris38375 [ Thu Jun 24, 2010 11:01 am ]
if the calipers and brake pads are new,anytime ive ever changed,the pads have to seat to the rotors before u would have good brakes,maybe a couple rides or
Author:  nitro_mudder [ Thu Jun 24, 2010 11:48 am ]
Also with all being new, it will take a ton of fluid to completely bleed it out. I think i ran a half gallon thru mine into empty 2 litter bottles.
Author:  ridenrace6 [ Thu Jun 24, 2010 12:32 pm ]
do you have a residual pressure valve inline?
Author:  Odyknuck [ Thu Jun 24, 2010 1:54 pm ]
A common mistake that guys make with new systems is not bench bleeding the Master. That needs to be done first.
