It is currently Sun May 03, 2026 6:21 pm
PostPosted: Thu Aug 16, 2007 6:35 pm
Is that just a piece of tubbing with a stem welded to one side and sharpened on the other?
PostPosted: Fri Aug 17, 2007 8:43 am
Have you got any more detailed pics Curt?
Thanks,
Blake
PostPosted: Fri Aug 17, 2007 1:01 pm
Thanks Curt, I'll be trying that sometime this fall.
-Blake
PostPosted: Fri Aug 17, 2007 9:21 pm
That is slick. Nice tool.
PostPosted: Wed Sep 05, 2007 5:05 pm
Curt brought the this tool by my shop sunday and in a mater of seconds cut 3 lugs off a set of boggers no smoke or mess I will be makeing this tool for my shop.
(LIVE EVERY DAY LIKE IT IS YOUR LAST) AND AS I TELL MY 10 YEAR OLD BOY ANYTHING BROKEN CAN BE FIXED
PostPosted: Thu Sep 06, 2007 11:08 am
Have you used these just to remove some plys on tractor tires. If so what size tube would you recommend?
PostPosted: Mon Sep 10, 2007 11:13 am
How well do these work?
http://www.pitstopusa.com/SearchResult. ... WAod4jd_wQ
What kind of pattern do you recommend for removing "V" grove tracter tire lugs. Is there any advantage to also doing the front "V" grove style tracter tires?
PostPosted: Mon Sep 10, 2007 11:17 am
Steve, I have the top one. That is what my son used to cut MadMike's and my tires. For the price, It's the best investment.
PostPosted: Mon Sep 10, 2007 11:29 am
I agree w/ DVS1. The bigger cutter (the one with the transformer) gets hotter and flies thru the flat area between the lugs, but you still gotta go back with the little one (or SOMEthing) to cut out the radius right in front of the lugs and sharpen them. The bigger one will eat up some blades, too. The smaller one is the way to go, unless you want to spend the money for both of 'em.
Larry
