front hub ?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=9503
Author:  ridenrace6 [ Tue May 18, 2010 2:16 am ]
Post subject:  front hub ?
not sure if this fits in the fabrication, suspension, or wheels section?
does anybody make a 4 lug hub that fits a kingpin spindle or what is the best way to to run 4 lug wheels on a kingpin front end without having to use one of those steel 5vw to 4vw adapters?
Author:  hillaholic [ Tue May 18, 2010 2:25 am ]
Post subject:  Re: front hub ?
Cut the baby spuds off and weld on some ball joint spuds. You can get a set of ball joint spuds for $20 and they don’t brake or bend as easy as the king pin spuds.
I think they make bearings for them but I don’t have the part numbers. I remember someone posting the part numbers here a while back, but I can’t find them.
Author:  turboblue [ Tue May 18, 2010 10:05 am ]
There are 2 different inner ball joint bearings.
If the spindle measures about 1.060" it's early to '68.
If it's 1.125" or so it is the late style.
Outer bearings are the same.
Your 4 lug hub can use either one.
We usually machine the brake surface off a drum to make those.
I can give you the part numbers if you need them.
Author:  dirtdobber [ Tue May 18, 2010 10:27 pm ]
chris ive got part number for bearings to inter change to king pin. i will get them from shop about 9 inmorning and post them for you. just cut drum flang off balljoint hub replace with conversion kit,Just done 2front ends last week.
Author:  ridenrace6 [ Tue May 18, 2010 10:35 pm ]
thanks matt thats what i was looking for
Author:  dirtdobber [ Tue May 18, 2010 11:23 pm ]
emp i k/p conv bearing inner 17-2795-0 empi k/p bearing outer 17-2796-0 1 bearing 1 race comes with each number
Author:  ridenrace6 [ Tue May 18, 2010 11:44 pm ]
so these bearings and races fit a ball joint hub to a king pin spindle, just wanted to make sure
Author:  dirtdobber [ Wed May 19, 2010 10:17 pm ]
???? dont know.. Ball joint hubs i got fit my Link pin spindles.. i think some are diffrent?? somebody help answer if you know.. mine works good may have some 1st of week if need to try before you buy. can drop off at house on way threw next week ,Just let me know.
