 Post subject: Which tranny for 1915
PostPosted: Thu Feb 18, 2010 3:51 pm
i have a 1915 motor with dual 44's on it whitch transmission would i be able to climb the best with a 6 rib or a 3 rib
 Post subject: Re: 1915
PostPosted: Thu Feb 18, 2010 7:38 pm
What tires are you running?
PostPosted: Thu Feb 18, 2010 9:38 pm
i have cut 23 degrees firestones with about half tread left on them
PostPosted: Thu Feb 18, 2010 10:01 pm
the 6 rib will work pretty good with 31's and that much engine
PostPosted: Thu Feb 18, 2010 10:05 pm
ok thanks but i have talked to people aroung the house and they said that a 1915 will not push a 6 rib
but i really want to put a 6 rib on the buggy
PostPosted: Thu Feb 18, 2010 10:06 pm
run aluminum wheels and climb in first
PostPosted: Thu Feb 18, 2010 10:08 pm
i already have steel wheels and i ran out of money, will that matter that i have steel wheels on it
PostPosted: Thu Feb 18, 2010 10:11 pm
run what you have but aluminum will help when you can find a deal
PostPosted: Thu Feb 18, 2010 10:13 pm
Id run a 5-rib unless your motor is built very well and has some good heads on it.Not to step on anyones toes here but i had a decent running 1915 and i had to work the clutch pretty hard on some hills until i switched to the 5-rib.Ive only seen a few 1915's pull a 6-rib like a stroker and one of those guys was Hollywood and Helmet guy.Of course this is my opinion though,just dont want to see a man get into a situation on a bad hill because of gearing.
PostPosted: Thu Feb 18, 2010 10:18 pm
He's right,,,the 5 rib is geared nice for your engine. You can put 4.86 r&p in the 6 rib and have the best of both worlds. Do it when you put in a super diff.
PostPosted: Thu Feb 18, 2010 10:23 pm
i already have the 6 rib i don't know what the motor has done to it, i just got the buggy yesterday and i got the 44's hooked up today
when i rode with this buggy the guy had a 3 rib on it and he would tack out really fast so i think i can run the 6 rib and do ok
if you use the clutch will i be able to keep my rpms up or not
PostPosted: Thu Feb 18, 2010 10:26 pm
just gotta try and see, In the mean time save up for a super diff. and find a side shift 091 for the R&P and get a good tranny man to install. The side shift is often a stronger case too. good luck
i can put a 4.86 r&p in the 6 rib with my 1915 on wait until i build a stroker
PostPosted: Thu Feb 18, 2010 10:31 pm
yea i'm going to take the buggy to d&k to that hillclimb and i'll see what it will do
does anyone know where the hill will be, at the playground or where?
PostPosted: Thu Feb 18, 2010 10:52 pm
Top Secret :shock:
PostPosted: Thu Feb 18, 2010 10:55 pm
come on why is it top secret
PostPosted: Fri Feb 19, 2010 7:08 am
the qualifying hill will be climbable by nearly any buggys.
The hills may or may not be chosen yet. so not to give anyone an advantage.
PostPosted: Fri Feb 19, 2010 8:52 am
im with buckmaster, i think youd be alot happy with a 5- rib!!!
PostPosted: Fri Feb 19, 2010 5:24 pm
well i'll probally just go ahead and put the 6 rib on it and build a stroker next winter
but i can't wait til the hillclimb at d&k
PostPosted: Sat Feb 20, 2010 10:17 am
if you have a 3 rib i would run it until you build the bigger motor.the 6 rib just seems to be to tall first gear.my friend just changed from a 3 to 6 rib with a 1915 and he is hating it on long climbs and says its like he is constantly in between the gearing he needs on the trails to lug around the woods.this is his experience with this combo.i like the 3 rib myself everybody says they break 1st gear easy but knock on wood i abuse the crap out of mine and have never tore 1st out,have ripped rev out a couple times but it was understandable for what i was doing when it happened.chad :mrgreen:
PostPosted: Sat Feb 20, 2010 11:21 am
I like the six rib. It lugs up the hills nicely.
PostPosted: Sat Feb 20, 2010 4:01 pm
i had a 1915 with a three rib and i liked it alot it took alot of abuse and never gave me any trouble first gear was a little short but as long as your motor can handle holding the rpms it beets runing out of power and gettin in a bad situation on a big hill
PostPosted: Sat Feb 20, 2010 4:30 pm
i think i am going to put the 6 rib on my 1915 because my papaw has a saturn buggy with a 3 rib on it and he can climb in 2nd gear, were also building another saturn buggy so i'm going to put my 3 rib on it
cron
