| what cables to use? http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=8758 |
| Author: | hauser2169 [ Tue Feb 16, 2010 7:35 pm ] |
| Post subject: | what cables to use? |
im close to hookin up my tranny and throttle. i need cables and the hardware. what and where can i buy it at? |
| Author: | MickeyMouse [ Tue Feb 16, 2010 8:35 pm ] |
| Post subject: | Re: what cables to use? |
It all depends on the amount of money you want to spend... Most of my buggy have used cables from a hardware store with wire clamps. I have always used steel brake lines to run the cables thru. On my latest rebuild, I added a hydraulic clutch and a Morse throttle cable. I really like the Morse cable but I have heard a lot of people do not like the Morse Cable. |
| Author: | dunebuggynut [ Tue Feb 16, 2010 10:56 pm ] |
I dont like running the throttle cable through a tube. It gets jammed up with mud & debris. I always weld eyelets along my frame & run the cable through them. Usually 3 is all I need to route the cable. I have done this for almost 20 years and never had a failure yet. This method leaves the cable exposed & as long as the eyelets are placed in the spots you need to redirect the cable there is nothing to gum things up. I always used the eyelets you bolt in since they have no sharp edges. ![]() You can bolt them in but I like to weld them to keep em in place. I usually run wire rope from Lowes since its cheap. Most Lowes sell a ferrule that you loop the cable & slide both ends through & crimp it which is perfect for the throttle pedal end. ![]() Total cost including eyelets is about 10 bucks. I usually run 1/16th which is overkill but lasts forever. Make up a second cable & keep it in your tool box. Youll never need it but its cheap insurance. Use a length of 3/8" brake tubing to pass the cable through your fan shroud. usually 4 inches is plenty. Just remember to avoid sharp edges so the cable doesnt wear on it. If you are going to run a clutch cable use a stock VW cable & a cable shortener that buggy shops carry. I use the stock Bowden tube to redirect the cable at the trans. |
| Author: | bmoore [ Tue Feb 16, 2010 11:49 pm ] |
i used a semi trl roll door cable,works perfect but not easy for everyone to get.dbn idea sounds easier |
| Author: | hauser2169 [ Wed Feb 17, 2010 2:56 pm ] |
yeah for the crips, good idea but i dont have a nicropress tool. i may be able to find one. how do you all secure the wires to the pedal assemble? |
| Author: | dunebuggynut [ Wed Feb 17, 2010 3:12 pm ] |
Usually Lowes has the crimp tool there in the wire rope dept. I make my loop there & crimp the connector before I leave the store. I make a loop about the size of a nickel & I run washers on both sides of the loop with double nuts to keep them in place. That bolt then threads into my pedal & I put another nut on the back to secure it. Heres the order.....I use a 1 1/4" long grade 8 bolt. I put a washer on it then the cable loop then another washer followed by double nuts leaving just enough slop so the loop doesnt bind. Then I screw this into the threaded hole in the pedal & put a nut on the back to tighten it well. |
| Author: | hyde [ Wed Feb 17, 2010 9:01 pm ] |
I youes 3to4 eyelets also & heavy duty throttle cable from Drews |
| Author: | nitro_mudder [ Wed Feb 17, 2010 9:22 pm ] |
I have used cables with the crimp connectors. I have never used a tool to crimp them. I have a short section rail road track that I place it on and beat it with a small sledge hammer. Hasn't failed me yet. |
| Author: | dunebuggynut [ Wed Feb 17, 2010 11:39 pm ] |
nitro_mudder wrote: I have used cables with the crimp connectors. I have never used a tool to crimp them. I have a short section rail road track that I place it on and beat it with a small sledge hammer. Hasn't failed me yet. You have heard of the right tool for the job? |
| Author: | nitro_mudder [ Thu Feb 18, 2010 12:43 am ] |
LOL, I thought i was ussing it. |
| Author: | turbo2332 [ Thu Feb 18, 2010 1:33 am ] |
i have always used wire cable from Tractor Supply. run it in 5/16 break line. the trick to keeping it from binding with crap in the line it to use a much larger tube than cable, and run the break line as close to the throttle peddle and carb set-up as possible. it will cost you like $15 to set up a nice clean lookin throttle cable that will last as long as your buggy. |
| Author: | hauser2169 [ Thu Feb 18, 2010 11:52 am ] |
K I got a nicropress tool from school. So make my own throttle cable and buy a clutch cable |
