Power Rack Modification
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=8322
Author:  Crash [ Sun Dec 27, 2009 7:42 pm ]
Post subject:  Power Rack Modification
For those that were interested, here is the write up on modifying the Corsica or Beretta power rack for use in a bug or sandrail. The mod allows you to put the rack against the back of the beam so installation is much simpler.
Mark
http://blindchickenracing.com/How_to/po ... errack.htm
Author:  Firebug [ Sun Dec 27, 2009 8:12 pm ]
Post subject:  Re: Power Rack Modification
That mod will make that rack an ideal steering setup,,thanks for posting. :wink:
Author:  ImmortalSoul219 [ Sun Dec 27, 2009 8:53 pm ]
Sweet Ive been waiting for these pics. Cant wait now to rip mine apart.
Author:  eggman [ Thu Jan 14, 2010 5:13 pm ]
Seems like that is alot of work when you can bolt it on with out al that work. One just has to be a bit conscientious when lining things up.
Author:  Firebug [ Thu Jan 14, 2010 6:24 pm ]
I ran that rack for a while with all the changes I could think of in alignment and never got the bump steer out. So I went to a econo rack that enabled me to get the geometry right. But I would still be using that rack if I could get the tie rods at the rack forward up near the beams to eliminate the bump steer without the tie rods hitting the rack ends. On a VW trailing arm front end the tie rods need to meet up near the beams or you will have bump steer.
