starters
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=8214
Author:  vw_brandon [ Sat Dec 05, 2009 12:06 am ]
Post subject:  starters
not sure where to put it so here it goes,
has anyone herd of a auto stick starter being a higher power and better starter?
Author:  A. Cole [ Sat Dec 05, 2009 1:06 am ]
Post subject:  Re: starters
it is better than regular sedan starter. and will work in sedan, bus 3,5 rib.,
Author:  vw_brandon [ Sat Dec 05, 2009 1:58 am ]
thanks for lettin me know!
had one layin around just needs the cyliniod < i reckin thats what its called
Author:  afterburnt [ Sat Dec 05, 2009 8:07 pm ]
I've been running those starters for years.That thing cranks over about 2276 with an 11 to 1 compression. Don't get them from autozone, they sell junk starters.
Dave
Author:  vw_brandon [ Sat Dec 05, 2009 10:14 pm ]
the one i got has bosch stamped right into it
Author:  Stevo [ Sat Dec 05, 2009 10:20 pm ]
These starters are great for anything with compression. I use one in my suby powered buggy but I use a three rib bell on my six rib trans. I got mine from carquest and its worked fine.
Author:  dunebuggynut [ Sat Dec 05, 2009 10:27 pm ]
Thats the starter you want to run. It eliminates the need for that bushing in the bellhousing. There are several lengths of this starter. The longer the housing, the higher the torque.
Author:  Firebug [ Sat Dec 05, 2009 10:56 pm ]
But,,,if your gonna buy a new starter,,,get the late model VW Beetle diesel automatic and alter the mounting holes a little and you will be astonished at how strong it is :!:
Author:  davehix [ Sat Dec 05, 2009 11:09 pm ]
did you do this? got any pics? and what bell housing did you use? thanks dave
Author:  Firebug [ Sat Dec 05, 2009 11:39 pm ]
I did, and am very impressed,, I use a 3 rib bell housing
http://www.woodsbuggy.com/index.php?opt ... =18&t=8032
Author:  vw_brandon [ Sat Dec 05, 2009 11:45 pm ]
i just noticed that my one starter like this where the ciloniod/sylinod what ever it is has 3 bolts to hold where it goes my old one has 2 will it still work, not meaning it has more bolt holes on the bell housing
