| your thoughts on shock towers http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=8012 |
| Author: | giveitagallon [ Fri Nov 06, 2009 9:19 am ] |
| Post subject: | your thoughts on shock towers |
well my ball joint front end was shot so i liked the setup on the king pin for off road i went ahead and cut the top frame horns off and switched over to king pin. after completing the task i purchaced the empi long travel shock towers and installed them . now im looking at this think saying to myself man one light roll and there going to bend huh |
| Author: | kybuggy1 [ Fri Nov 06, 2009 9:33 am ] |
| Post subject: | Re: your thoughts on shock towers |
Depends on how/where you ride. I see no point at all in them for woods riding, JMO. Larry |
| Author: | RaceBugg1098 [ Fri Nov 06, 2009 9:34 am ] |
Thats easy! Just try to avoid the formentioned event! |
| Author: | DUBclub [ Fri Nov 06, 2009 9:41 am ] |
well i might be out of line or in left field but you could just do a beam without towers and then make whoops...that is what im building for mine... but i dont know if that is a valid option for you lets not forget that it makes your ride unique and more of a one of a kind... |
| Author: | chris38375 [ Fri Nov 06, 2009 6:46 pm ] |
since u allready got them try and figure out a way to brace them,,maybe allway across or something |
| Author: | kantgitrite [ Fri Nov 06, 2009 8:09 pm ] |
check out the buggy on the cover of this months sand sport mag, maybe something like that would work. |
| Author: | giveitagallon [ Fri Nov 06, 2009 9:21 pm ] |
C:\Documents and Settings\HP_Owner\My Documents\My Pictures\250X\DSC00733.JPG |
| Author: | giveitagallon [ Fri Nov 06, 2009 9:39 pm ] |
| Author: | RaceBugg1098 [ Fri Nov 06, 2009 11:11 pm ] |
don't worry about it! If you roll hard enough to bend them that bad, that will be the least of your concern. If it helps, look at the towers I just built... I'm not worried about bending them, and they are way thinner than yours(lighter).
| Author: | plumberbill [ Sat Nov 07, 2009 5:46 pm ] |
i use the warrior beam with the shock towers kicked back for coilover shocks. the biggest problem was the shock tower twisting. i added a piece of 1" square tubing to stiffen it up. your towers are for non-coilover shocks but you might be able to work something in. dont worry about your shock towers in a roll, pay more attention to your roof. some x-bracing would be nice.
