Broken bug...
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=7237
Author:  jarfly [ Thu Jul 23, 2009 10:12 pm ]
Post subject:  Broken bug...
Went out ridein to night wile doin a small hill I hit a rock and bottomed out in a rut HARD..Now all my right side axle does is spin? The left does nothing.I am thinkin a cv? Also my right axles has a lot of slop in it now. I have a bus trans. I dont know what axles or stubs I have it is a irs rail.
Author:  DVS1 [ Thu Jul 23, 2009 10:16 pm ]
Post subject:  Re: Broken bug...
More than likely its a cv. watch the axle spin and then watch the cv's if the axle spins and the cv doesnt then thats the problem
Author:  jarfly [ Thu Jul 23, 2009 10:34 pm ]
That is what it is then. Will the stock unints work or am I better off gettin differnt ones?
Author:  harleyhunter05 [ Thu Jul 23, 2009 10:57 pm ]
stocks will work - but you have to know if it is car or bus on the stub axle side -- when alot of people switch to bus trans. they use an bus cv on the trans side and a car cv on the tire side. the bus cv's are bigger in diameter than car ones.
If you have bus on each side change it with a stock one if you have extras -- if you have to buy one buy one for a vw thing , they allow you a little more angle than stock bus cvs
Hope this helps ya,
larry
Author:  dbg1977 [ Fri Jul 24, 2009 6:10 am ]
I don't know your financial position, but if you want to fix that problem for a long time, buy a porsche 930 kit. I am ordering one soon and I am told they will hold up for a long time.
Author:  jarfly [ Fri Jul 24, 2009 10:51 am ]
HAHA..Im a poor high school kid.lol Yea 930s will be over the winter when I rebulid thw whole thing. Im goin to tare it down today and see what happin..Is there any way to protect the axles/cvs on a bug?
Author:  turboblue [ Fri Jul 24, 2009 10:54 am ]
They are really strong..........and expensive........... 8)
The riding style of most around here is better geared toward a bus to bus setup.
That bus CV acts somewhat like a fuse so it's less likely to break transmissions.
Just another opinion.............. :wink:
Author:  perrib [ Fri Jul 24, 2009 12:05 pm ]
I was a member of the broken cv joint club for a while. Just keep a couple of spare axles in the car. I had one friend go all out weld two steel plates to hold two axles under the hood of a Baja. Out of your budget but even a set of Sway Away axles will help stock joints last longer. Any engine other than stock needs larger CVs.
Author:  jarfly [ Fri Jul 24, 2009 12:16 pm ]
Yes over the winter I am goin to get a set of 930s and sway aways for the longer trailing arms. I am thinkin I have bus cvs at both ends. I ant for sure.How do I tell?
Author:  Odyknuck [ Fri Jul 24, 2009 12:19 pm ]
Go here: http://www.blindchickenracing.com/How_t ... ts_101.htm
