It is currently Tue May 05, 2026 7:21 am
 Post subject: 3x3 trailing arms
PostPosted: Sat Jun 27, 2009 12:06 pm
I am changing the trailing arms on my buggy. I got these from Jim's Custom VW. I was wondering if anyone has any advice that I may need before I put them on. The old 3x3 arms that came on my buggy were a bit out of alignment. So I am replacing them. I have all new bearings and seals. I am using the old 930 stub axles. I have welded on the brake brackets and the shock mounts. I was also wondering how strong these arms are. Is there anyone on here broke a set of this type or arms.
 Post subject: Re: 3x3 trailing arms
PostPosted: Sat Jun 27, 2009 2:07 pm
They make different quality of arms. Depending on your type of riding and avoidence of trees, they should be fine. I would have waited too weld your caliper mount till you mounted the arms with stub rotor etc...
PostPosted: Sat Jun 27, 2009 4:59 pm
I have no first hand experience with Jim's fabricated parts, not even sure he makes them. I do know I have looked at them and liked what I saw, seem to be well built no matter who's making them. He offers a bunch of fabricated stuff from time to time, all looks good and right.
PostPosted: Sat Jun 27, 2009 5:43 pm
it looks like a set of empi trailing arms,if ur old trailing arms was out of alignment,dont be surpised if these are out to,the cup thats welded to the torsion could be off a little,and like mike said,u might j
have to cut the caliper bracket back off
PostPosted: Sun Jun 28, 2009 6:44 pm
I sure hope these will be straighter than the old ones. On the old ones the right rear wheel leaned out so much that the buggy wanted to pull to the right all the time. As for the Caliper brackets. I used the old brackets to make a holding fixture. Even after all the careful calculations and welding. I still had to machine the bracket so they would fit right. I got the arms mounted. So when I get my heads back from Jim. I can put the motor back together.
