It is currently Tue May 05, 2026 6:09 am
PostPosted: Tue Jun 09, 2009 9:31 pm
ok i have disc on the back and dont have none on the front but i have a kit to put drums on the front whats your alls imput on this? can i use the drums with a 15 inch steel rim with the 3 rib tractor tires? or do any of you have a kit or some off a old bug you want to sell?
im on the road like 80% of the time would you put them on it or what?
Brandon
PostPosted: Tue Jun 09, 2009 9:37 pm
Run disc brakes, well worth the extra $$$ You will never have to mess with them once it is setup right.
PostPosted: Tue Jun 09, 2009 9:55 pm
my opinion disc definetly bettr... but drums better than nothin till u decide 2 upgrade.
PostPosted: Tue Jun 09, 2009 10:59 pm
about what would disc brake kit for the front cost?
Brandon
PostPosted: Tue Jun 09, 2009 11:21 pm
Pretty big money if you got k/p spindles. At least 500 as far as I've seen. If you got b/j, or you weld b/j spuds to your k/p spindles, you can do it for less than 200 with used rotors and calipers, including seperate m/c and handle. Putting them on a seperate handle is a must in the hills, IMO.
PostPosted: Tue Jun 09, 2009 11:48 pm
well would you all leave no brakes on the front or put the drum brakes on the front? has anyone of you guys had trouble with drum brakes?
Brandon
PostPosted: Wed Jun 10, 2009 1:27 am
IMO, for the woods, leave 'em off until you can get discs. Drums in front are useless when they get wet n muddy.
PostPosted: Wed Jun 10, 2009 1:34 am
Yes drums are COMPLETELY useless when the get wet and muddy. Take them off for the weight reduction until you put front disk on. I just run rear disk and they work fine for off-roadl. I wouldn't drive it on the street with just rear disk though.
PostPosted: Wed Jun 10, 2009 4:21 am
wow even tho im on the road like 80% of the highway they wouldent be any good?
Brandon
PostPosted: Wed Jun 10, 2009 3:42 pm
I forgot you had said that in your first post. Sorry :oops:
Yeah, put 'em on, with a proportioning valve. No need for seperate handle on the street I wouldnt think.
PostPosted: Wed Jun 10, 2009 6:16 pm
no problem kybuggy1 what is that valve your talking about?
Brandon
PostPosted: Thu Jun 11, 2009 12:07 am
http://www.summitracing.com/parts/SUM-G3905/
So you can independently control how much pressure is applied to front and rear brakes. Without one, your fronts will most likely lock up way before your rear brakes, and just slide, losing your ability to steer and increasing stopping distance. May not be as bad with drums, though. :?: Maybe try it without one first, you can always add one if necessary. Rails on the street are uncharted territory for me. There are many on here that would know better than me what works for streetrails.
PostPosted: Thu Jun 11, 2009 2:19 am
well truthfully my buggy aint street legal its just a starter buggy i guess you could call its its my first one aint had it 3 months its a 1600cc 3 rib trans with tractor tires on the rear been cut and the rib one on the front its a beeline cobra i usually ride around this hollows to get to close jobs and stuff like that but when me and my uncle was coming off a steep hill and the buggy started scootin with us so im wantin to get some kind for the front! but im just on the main road id say like 15 mins a day but its just a 2 lane country road never see many cops on it but when i do see them believe me i dont drag around cause they are mostly little young punk cops anyway :twisted:
Brandon
Users browsing this forum: No registered users and 5 guests
