| electronic ignition? http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=6796 |
| Author: | bssford460 [ Thu Jun 04, 2009 8:43 pm ] |
| Post subject: | electronic ignition? |
what is the best electronic ignition to get for a buggy. and where is the cheapest/fastest place to get it from? |
| Author: | Baddvw [ Thu Jun 04, 2009 10:48 pm ] |
| Post subject: | Re: electronic ignition? |
Go for MSD from Jeg's, they are very reliable and can get it in 2-3 days if ordered by 9:00 pm |
| Author: | bssford460 [ Thu Jun 04, 2009 10:51 pm ] |
i was thinking more along the lines of pertronix or something like that? not the full blown msd 6al if that is what your talking about? |
| Author: | Baddvw [ Fri Jun 05, 2009 12:01 am ] |
Pertronixs are very good ignition system too, it is just a distributor and a coil-pack, I run a MSD electronic 6AL, (far different from the regular 6AL), a MSD Billet distributor, and a MSD Coil-pack. I believe in the MSD, NASCAR, NHRA, Late-model racing, just about every motorsports out there runs a MSD system. It is just my opinion, I know there are others out there that works well. |
| Author: | ridenrace6 [ Fri Jun 05, 2009 2:20 am ] |
if u are gonna stick with vw distributor definetly go with petronix and bosch blue coil and dont waste time on compufire or computronix they are junk imo as i have run both and the magnetic trigger that goes under the rotor allways gets loose and is cause for inconsistant timing issues wheras the petronix fits tight and stays that way |
| Author: | bssford460 [ Fri Jun 05, 2009 7:59 pm ] |
yeah. already got the blue bosch coil. whats the best place to get the pertronix? |
| Author: | Baddvw [ Fri Jun 05, 2009 10:12 pm ] |
Drew's Off Road |
| Author: | Eric DeBord [ Sat Jun 06, 2009 6:29 pm ] |
Toyota truck modded (22R engine with carb, not F.I). Works great, and cheap. I removed the secondary advance spring so the advance comes in quicker. |
| Author: | MickeyMouse [ Fri Jun 12, 2009 9:23 pm ] |
If you are interested in a full MSD ignition system, I will be selling my MSD "Off Road" ignition box, rev limiter, coil and distributor. I am converting to a Subaru and will not need it anymore. I also have a bosh Alternator and a Weber carburetor. |
| Author: | aboone993 [ Fri Jun 12, 2009 9:36 pm ] |
mm How much ? |
| Author: | MickeyMouse [ Fri Jun 12, 2009 10:11 pm ] |
I am sure yet... The Ignition system was roughly $800 and the carb was $400 plus the Alt was another $200.. I am thinking around $550 for the entire engine. I know the heads need some work but other than that the engine is great. |
| Author: | gasman [ Fri Jun 12, 2009 10:15 pm ] |
pm sent.chad |
| Author: | khaney01 [ Sat Jun 13, 2009 10:24 pm ] |
Eric DeBord wrote: Toyota truck modded (22R engine with carb, not F.I). Works great, and cheap. I removed the secondary advance spring so the advance comes in quicker. I've got one from a Mitsubishi. They work pretty well. Eric knows what he is talking about on this one. |
