It is currently Tue May 05, 2026 6:07 am
PostPosted: Mon May 11, 2009 11:50 pm
It got dark on me before I figured it out. I ran a wire straight from battery to coil and still no spark.... Any ideas? http://www.youtube.com/watch?v=YIc2MdwY5j0
PostPosted: Tue May 12, 2009 12:10 am
could be the coil,the points,condensor,really not enough info
PostPosted: Tue May 12, 2009 12:32 am
Well, Everything is new! I have new 009 distributor with electronic ignition, New bosch blue coil. ?Im bot sure what you mean by condensor?
PostPosted: Tue May 12, 2009 12:38 am
condensor is on the side of the dist.but u aint got points no more so no condensor,the electonic ign.could be bad,could have hooked up backwards on the coil and burned it up,i dont know much about eletronic ign.,i dont run a vw distrubtor,dont give up;;;;; good luck
PostPosted: Tue May 12, 2009 9:07 pm
does ur coil get real hot when u try starting it
Users browsing this forum: No registered users and 5 guests
