| 120cc two stroke buggy http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=598 |
| Author: | hillaholic [ Mon Jun 04, 2007 12:43 am ] |
| Post subject: | 120cc two stroke buggy |
Check this thing out.. http://www.fieroaddiction.com/buggy.html I need to build one so when my jets are plugged I can still have some fun |
| Author: | D. Marks [ Mon Jun 04, 2007 2:59 am ] |
| Post subject: | |
Thats crazy. Never seen anything like that before. Have you messed with your carbs yet or are you still pissed at them? |
| Author: | Roy [ Mon Jun 04, 2007 4:39 am ] |
| Post subject: | |
Brad, Don't forget to check your fuel pressure and make sure it's not to high. I think that is part of your overall problem. Not the clogged jet problem but the drivabality. |
| Author: | Eric DeBord [ Mon Jun 04, 2007 7:27 am ] |
| Post subject: | Re: 120cc two stroke buggy |
[quote='hillaholic']Check this thing out.. http://www.fieroaddiction.com/buggy.html I need to build one so when my jets are plugged I can still have some fun[/quote] Having plugged idle jet probs? I fought with mine for 5 years until I finally fixed it. To make a long story short, the problem was in the fuel filters. I used a "sintered bronze" element (that originally was made for a chevy quadrajet- the kind that you un-screw the fitting and put the filter back |
| Author: | hillaholic [ Tue Jun 05, 2007 12:47 pm ] |
| Post subject: | |
[quote='D. Marks']Thats crazy. Never seen anything like that before. Have you messed with your carbs yet or are you still pissed at them?[/quote] I'm still pissed at them. I grounded my buggy and made it stay outside for a week. |
| Author: | hillaholic [ Tue Jun 05, 2007 12:50 pm ] |
| Post subject: | |
[quote='Roy']Brad, Don't forget to check your fuel pressure and make sure it's not to high. I think that is part of your overall problem. Not the clogged jet problem but the drivabality.[/quote] I |
| Author: | FlaBaja [ Tue Jun 05, 2007 12:53 pm ] |
| Post subject: | |
[quote='hillaholic']I'm still pissed at them. I grounded my buggy and made it stay outside for a week.[/quote] |
| Author: | hillaholic [ Tue Jun 05, 2007 3:01 pm ] |
[quote='Eric DeBord'] Having plugged idle jet probs? I fought with mine for 5 years until I finally fixed it. To make a long story short, the problem was in the fuel filters. I used a "sintered bronze" element (that originally was made for a chevy quadrajet- the kind that you un-screw the fitting and put the filter back into a hole). I machined some brass fittings and pressed the filter into them, then soldered on the ends. The difference was like night and day. I think I have clean |
| Author: | Roy [ Tue Jun 05, 2007 3:26 pm ] |
| Post subject: | |
[quote='hillaholic'][quote='Roy']Brad, Don't forget to check your fuel pressure and make sure it's not to high. I think that is part of your overall problem. Not the clogged jet problem but the drivabality.[/quote] I |
| Author: | hillaholic [ Tue Jun 05, 2007 6:03 pm ] |
| Post subject: | |
I don |
| Author: | hillaholic [ Tue Jun 05, 2007 6:22 pm ] |
| Post subject: | |
The lower the micron rating the better, correct? |
| Author: | TrackerCasey [ Tue Jun 05, 2007 6:47 pm ] |
| Post subject: | |
Yep! |
| Author: | Odyknuck [ Wed Jun 06, 2007 11:04 am ] |
| Post subject: | |
Yep that would definatly clogg your Pilot jets over and over. I suspect that the screens still let enough crap thru to clog them. It does not take much |
