It is currently Tue May 05, 2026 7:29 am
 Post subject: Ebay find neat idea!
PostPosted: Fri Jan 30, 2009 6:08 pm
http://cgi.ebay.com/ebaymotors/Grease-N ... 240%3A1318
 Post subject: Re: Ebay find neat idea!
PostPosted: Fri Jan 30, 2009 6:26 pm
cool idea but a little pricey.
"Lets go get stupid"
PostPosted: Fri Jan 30, 2009 6:53 pm
Thats what I thought too. Wonder if you could drill the cv a put a fitting in?
PostPosted: Fri Jan 30, 2009 8:00 pm
Now your thinking.. Or some kind of fitting that just slides around the axle with a fitting..(removable)
PostPosted: Fri Jan 30, 2009 10:12 pm
I use zip ties on the small side of the boot. Cut the zip tie off, get my grease needle slide it under the boot end and grease away. I do that every 2 or 3 rides.
PostPosted: Sat Jan 31, 2009 8:38 am
Awesome idea!
You could drill a 1/8" hole from the outside of the cv down into an area that does not have a ball track.
You would then drill a short distance from the outside for your grease fitting.
You could keep a flathead dummy grease fitting in the holes until you need to grease the cv.
a.k.a."PittsburghJim" on www.dune-buggy.com
PostPosted: Sat Jan 31, 2009 9:10 am
Awesome idea!
You could keep a flathead dummy grease fitting in the holes until you need to grease the cv.[/quote]
Exactly what I was thinking! If you drill it close ti the tranny flange in the thick part of the cv, what would it hurt.
PostPosted: Sat Jan 31, 2009 1:48 pm
Couldn't one put two grease zircs 180 degrees apart and you wouldn't have to take them out.
PostPosted: Sun Feb 01, 2009 3:31 pm
if you left the zerks in the cv they would get all nasty muddy and prolly get snapped off on something in the woods, but like jim said about the dummies, thatd work
