PostPosted: Mon Dec 15, 2008 12:12 am
IV GOT A SMALL BLOCK CHEVY out of a 89 k5 its tbi id like to run it on lp but cheep i dont want to order some high doller kit. what do i need?
PostPosted: Mon Dec 15, 2008 12:36 am
http://www.propane101.com/index.htm
for when the weber acts up. sorry willie could not help myself
PostPosted: Wed Dec 17, 2008 7:37 pm
So why propane other then in a roll-over? What are the advantages? I think its better on inclines but any different then EFI?
PostPosted: Wed Dec 17, 2008 8:41 pm
Any one that has ever ran propane will tell you it is the way to go .Its so simple plus it is like over 100 octane way over. So high compression motors love it. you need a bottom plate off a Holly carb 4 brl it will bolt right on a 425-Model E unit {CURT RUNS 2} but thats all you need . As a mater of fact you say it has a T-Body on it now you can use that disconect the gas line plug it they make a hat that goes where your breather goes now the 425 Unit bolts on your in like Flinn.Use your butter fly flaps in your T-Body don't even have to mod the T-cable. You can call a guy in Al he is a propane dealer specialist he has every thing you need his name is [Buddy Cambell call him at 205-591-2266] Tell him RockRockets sent ya
P.S.
sorry it took so long just saw this
PostPosted: Wed Dec 17, 2008 9:00 pm
thanks rock!now i have a few more? tamms big truck is the one i want to run on lp the motor i just put in is a 350 vortek motor witch one would be better to run it or the 89 350 0ut of the k5 and once i hook up the lp i can rip all the computer stuff out and wire the motor up like a old school v8 right.
PostPosted: Wed Dec 17, 2008 9:33 pm
unless the trany is ran threw the ICM
PostPosted: Wed Dec 17, 2008 9:42 pm
well that part of the resone im going to lp is iv got a bull dog 4 speed and a ford 205 twin stick im puting in and once i do that the comp .is going to make it run like shit unless i get the comp. redone. so id like to rip it all out and make it simple whier can i find some used lp stuff cheep!
PostPosted: Wed Dec 17, 2008 9:52 pm
I C said the blind man .The new set up is like 500 bucks new put a HEI dist on it and you will be very happy
PostPosted: Wed Dec 17, 2008 10:01 pm
IM LOOKIN TO GO CHEEPE THEN THAT IV GOT A TANK andican get hose and fittings tam wont let me spend to much $$$ she wants new floors put in at home. and iv got a good dis.
PostPosted: Wed Dec 17, 2008 10:05 pm
A lot of time used propane stuff is worn out thats why it for sale just so u know
PostPosted: Sat Dec 27, 2008 10:34 pm
well iv got all my propane stuff together ill post some pics so i can get some help hooking it up i tryed to find a diagram but could not find one +what do i use to clean the parts up a bit?
PostPosted: Sun Dec 28, 2008 12:35 am
I got nothing for ya, but i wanna see it when your done..
PostPosted: Mon Dec 29, 2008 10:38 am
ok this is what iv come up with now some one tell me what all of it is and how it hooks up.and i keep reading some thing about tuneing it in????? is this all i need?Image
PostPosted: Mon Dec 29, 2008 3:38 pm
wildwillie wrote:
ok this is what iv come up with now some one tell me what all of it is and how it hooks up.and i keep reading some thing about tuneing it in????? is this all i need?Image shut off valve
Image clockwise from back left: mixer, evaporator, shut off valve
Image evaporator
Almost everything. You still need the obvious-- intake to mount the mixer, large vapor line to connect the mixer to the evaporator, high pressure line from evaporator to shut off valve, and high pressure line from shut off valve to tank. You will also need the throttle plate to go between the mixer and the intake manifold.
PostPosted: Mon Dec 29, 2008 6:32 pm
what do you mean by high pressure line/hydrolic line and how big dose the line need to be.
PostPosted: Mon Dec 29, 2008 7:51 pm
The high pressure line can be made up at a hyd. shop its made with LP hose it will have brass ends. The model E reg has 1/4 pipe thread in. The hose can be made up with a female JIC end then use a 1/4 to JIC adp. If you use a fork truck tank you will need a Rego coupler. The vaper line can be hard piped with a pipe 1'' nipple a few inches long if you have room. The fork truck tank will need the safety valve removed.
Travis
PostPosted: Mon Dec 29, 2008 8:54 pm
I almost forgot.. the throttle plate can be removed from a holley 4 barrel carb it has the same bolt pat.
Travis
PostPosted: Wed Mar 18, 2009 11:42 pm
im workin on my truck agian iv got the lp hooked up i droped the dist.in and power run to it.im not geting any spark and how can tell if im geting lp to the mixer?
PostPosted: Sun Mar 22, 2009 1:18 am
get a test light and make sure you've got power when cranking. also make sure there's no voltage when the ignition is turn off.
PostPosted: Sun Mar 22, 2009 9:12 pm
With the air cleaner off pull up on the air valve on the mixer and push the primer button on the reg.you should smell lp. If not you mite have a prob. down stream of the reg. Be careful with the LP it likes to lay low and hang around. It would be a lot safer working on it outside.
Travis
