It is currently Tue May 05, 2026 4:56 am
 Post subject: frames,axles
PostPosted: Sun Dec 14, 2008 12:07 am
this is my firts year with a woodsbuggy, late november i rolled on killer in wellsville oh, bent up frame and axle. i would like input on what 2 seater frame to get. and i am running a car trans and axle i have no complaints with this set up it hooks up well but i am told i should switch to bus and cv what do you think? thanks, and hill climing is so much fun im addicted
 Post subject: Re: frames,axles
PostPosted: Sun Dec 14, 2008 12:19 am
Check out these: Predator frames, southern buggies, Bee-Line, some of the Berrien frames. I run a Berrien myself, it is light and strong so I can get by with less motor and tranny. If you stay with stock trailing arms car cvs actually do decent but bus are definately better. if you go 2X3 or 3X3 arms go ahead and get the 930 cv's, you'll save money in the long run
Welcome to Woodsbuggy.com!
Kev
Aut Viam Invenium Aut Faciam!
PostPosted: Sun Dec 14, 2008 12:22 am
this is the one i got its the third frame down the list http://www.dansperformanceparts.com/bug ... frame1.htm
PostPosted: Sun Dec 14, 2008 11:21 am
i run 2x3s and bus on both ends,i have broke 1 joint in 3 yrs,with a 2180,if ur arms are set up right its hard to break a bus joint,i wouldnt spend my money on 930s if bus joints work,,i also got a sandfox 4 seater for sale,it has been made into a 2 seater
