 Post subject: cv's
PostPosted: Thu Dec 04, 2008 6:29 pm
I am going to get some 930 cv's and was wondering if these would be good ones to use.
http://www.offroad-engineering.com/930cvjoint.html
If i would get undersized cv balls what size would be best I found .874 or .873. I think they come with .875
 Post subject: Re: cv's
PostPosted: Thu Dec 04, 2008 7:00 pm
These will work just fine....you should have no problems with these CV's, they are high quality ones....especially the Lobro ones, what size trailing arms are you running? if you are running 2x3, get 18-3/4 axles, 3x3, get 19-1/4 axles.
PostPosted: Fri Dec 05, 2008 8:24 am
Your better off to stay wih the Lobro balls and polish the star and inside of the cv. The aftmkt balls are cheaper metal. The polishing will clearance the joint just a hair, and remove burrs for the balls to snag and bind on.
Larry
PostPosted: Fri Dec 05, 2008 2:34 pm
larry is right spend the time to sand and polish the cage, star, and outer ring and thay should last a long time.
