soft ride?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=4757
Author:  duneman [ Sat Sep 27, 2008 10:21 am ]
Post subject:  soft ride?
what is the best set up 4 front suspension to get a soft ride? right now the front is as hard as a rock.
here is a pic of it if it will help: Image
Author:  rockrockets1 [ Sat Sep 27, 2008 12:49 pm ]
Post subject:  Re: soft ride?
longer front arms. the longer the travel the softer the ride :D
Author:  Stevo [ Sat Sep 27, 2008 1:14 pm ]
I think you can remove a couple of leaf springs from each bar
Author:  A. Cole [ Sat Sep 27, 2008 2:58 pm ]
Has it been sitting for awhile? My old BJ beam on my old car was really stiff likely from sitting for awhile. It softened up after a little riding. And give a good greasing....
Author:  MadMike [ Sat Sep 27, 2008 6:35 pm ]
First make sure everything is working as it should be. Longer arms like Rock said + coil-overs or Fox aIr shocks.
Author:  kyjr.buggy1 [ Sat Sep 27, 2008 6:37 pm ]
Longer arms, stock beetle bushings, and stock length regular old auto zone shocks that are only 20 bucks a peice or less with a lifetime warranty.
-Dakotah
Author:  wreckincars [ Mon Sep 29, 2008 12:00 am ]
I have the same problem. Dude is right, cheap gabriel gas shocks from autozone work the best. Grease it often. Jump it often. Keeps it kinda soft. I see your from Lagrange, Go jump the greens at pheasant run some night. lol
Author:  DVS1 [ Mon Sep 29, 2008 8:34 am ]
-Dakotah
Yeah, just don't tell them that you use them offroad. They won't warranty them. That's been my experience.
Author:  hillaholic [ Mon Sep 29, 2008 8:45 am ]
Mine was pretty stiff (don’t women like it that way?) :D
I removed all the split springs, top and bottom, and it’s still a little to stiff. I have a thing front beam so I don't know if the springs are stiffer to compensate for the weight of the thing.
Were going to Wellsville this weekend, bring it and Wellsville will loosen it up if it’s just from sitting.
