It is currently Tue May 05, 2026 1:02 am
 Post subject: trailer deck
PostPosted: Tue Sep 16, 2008 10:50 pm
I need to put a deck on a new trailer so I bought pressure treated wood. I started thinking if steel bolts will rust out in a year or so won't my trailer? I can put pain pine borads they would last just as long but don't realy want to use them. What do you guys think??
Dave
|....BUDWEISER......| ||'|";, ___.
|_..._..._______===|=||_|__|., ] -
 Post subject: Re: trailer deck
PostPosted: Wed Sep 17, 2008 5:55 am
The best thing to use would be Oak boards, they are pricey, but the will last a liftime. Thats what is on most heavy equipment trailers, and low-boys. If you have a wood yard or saw mill close by I would check the price and compare it with pressure treated. May not be worth it to you?
PostPosted: Wed Sep 17, 2008 7:30 am
If you go with treated make sure you use the new galvinized bolts. They switched the treatment and if your noit using the right hardware it will eat steel up. You will get a few years out of treated though.
PostPosted: Wed Sep 17, 2008 2:40 pm
I knew about the bolts but what about the trailer will it eat the floor beams?
PostPosted: Wed Sep 17, 2008 4:24 pm
I always deck mine with 1/8 diamond plate, steel diamond plate that is.
PostPosted: Wed Sep 17, 2008 7:37 pm
The best thing to use is ruff cut oak boards. I would find a saw mill in your area and go there. I have seen people try to use treated lumber on there trailiers and it does not last long. Plus the stuff they use to treat the wood is really slippery when it gets wet. You will pay alittle more for the oak, but it will last twice as long.
YOU ONLY NEED TWO TOOLS IN LIFE WD40 AND DUCT TAPE. IF IT DOESN'T MOVE AND IT SHOULD, USE THE WD40. IF IT SHOULDN'T MOVE AND IT DOES, USE THE DUCT TAPE
PostPosted: Wed Sep 17, 2008 9:33 pm
one other wood u could use is poplar,its light and will never rot as long as it dont touch the ground
PostPosted: Thu Sep 18, 2008 12:34 pm
Your trailer should not rust out in a year or so... Keep it painted and you should be fine. I have had my trailer for 5 years with no problems. The crappy plywood is a little worn out but the frame and bolts are just fine.
