It is currently Tue May 05, 2026 4:56 am
PostPosted: Mon Jun 30, 2008 11:49 am
What's the best way to attach the cable to the gas pedal. I have the pedal with the three tapped holes for a 10/32 screw in the side and I have just a bare cable to attach. I was thinking a crimped ring terminal or maybe a sleeve with set screws?
Bryan
PostPosted: Mon Jun 30, 2008 12:39 pm
Morse Cable with a hiem joint.
PostPosted: Mon Jun 30, 2008 3:54 pm
I cut a small (about 1/2" long) piece of brake line then slid it over the cable then crimped a heavy duty ring connector to the cable then crimp the brake line over the ring connector this way is very strong.
PostPosted: Mon Jun 30, 2008 4:03 pm
I just bolted a small eye bolt to the side of the pedal thru the holes, then run the cable thru the eye and make a small loop out of the end of the cable with a couple cable clamps.
Sometimes heavy duty cables come with a small ring end on them you could run the 10/32 screw thru.
Each to their own, but morse cable didnt work out for me at all.
If you are gonna woods ride alot and get in muddy and/or wet conditions ever , it may hang up and bind up all the time after only a few rides.
PostPosted: Mon Jun 30, 2008 5:24 pm
Make it in to an oiler system and it will last a life time and never hang up!! The best system out there!
PostPosted: Tue Jul 01, 2008 8:35 am
Hate to ask a dumb question (again) but what's an oiler system. Never heard of one.
Bryan
PostPosted: Tue Jul 01, 2008 12:07 pm
You run your cable through a Brake line (some what bigger). Toward the back of the buggy you install an in line T with a short (1 foot) piece in the 3rd part of the T (with it pointing up) so you can add oil to the cable. As long as you keep oil in it (every 2 or 3 rides) it will not freeze up or gum up. Cheep but very reliable. There is a cable end that you can crimp to the cable to attach to the pedal. (I do not know what it is called) but it has a flat side to it so you can drill a hole in it to bolt it to the pedal. You can also buy the cables from a buggy shop with them already attached. ($7.00 to $15.00)
PostPosted: Wed Jul 02, 2008 8:44 am
This is what I came up with. Will work for now. I'm sure I will modify the whole throttle cable, not real happy with the "feel" of it right now.
Bryan
PostPosted: Sat Jul 19, 2008 9:08 am
Rubber vacuum cap with a hole poked in the end works well as a boot to keep the water out of the cable jacket.
PostPosted: Sat Jul 19, 2008 5:18 pm
I've watched motor cycle mechanics make up custom cables. They run the cable across a soap or wax like block to pre lube it before putting it in outer sheath. Try phoneing some of your local bike or marine shops about it.
PostPosted: Sun Jul 20, 2008 7:40 pm
i got a heavy duty cable, it came with a steel eyelet already on it 12.00 at my local bug shop
PostPosted: Tue Jul 22, 2008 12:45 pm
i have 2 cable spliceing companys in a near town, i had em do me up a 3/32 cable with an eye /liner on one end, then i jusy put a 1/4 bolt through the eye
