It is currently Tue May 05, 2026 2:30 am
PostPosted: Mon Jun 30, 2008 9:29 pm
I just pick up a set of 33x12.50 boggers. What size (width) rims to you all run. I would guess to run an 8" but thought maybe a 10" will spread the tire a bit and make it a bit softer.
PostPosted: Mon Jun 30, 2008 9:57 pm
some 10" spread my 35x10.5's pretty good,,I would think at least 10",, maybe wider.
PostPosted: Mon Jun 30, 2008 11:41 pm
my buddy runs a 10 with same tires.
"Lets go get stupid"
PostPosted: Tue Jul 01, 2008 12:06 am
Go with 10" 8" is to small make sure you check what backspace you need before you buy rims?You dont want to have to remount shocks and any thing else they might hit!
aaron
PostPosted: Tue Jul 01, 2008 3:07 am
Hill Climber
I have 14" wide boggers and I have a 14" wide rim.
Harry S. Truman
PostPosted: Mon Jul 07, 2008 10:58 pm
I run 33x14x15 boggers on 15x14 with 5" backspacing Weld wheels with racing tubes and it works great!! For a 12.50 wide bogger I would a 10" wide rim, if 12" wide you will need to use tubes.
cron
