| Seats http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=3619 |
| Author: | nickschlemer [ Tue Apr 15, 2008 2:18 pm ] |
| Post subject: | Seats |
Does anyone on here mount there seats so they lean back farther than normal. This is what im planning on doing so i was wondering if anyone has built a raised crossmember for the front seat mounts. Any ideas and pics would be helpful. Thanks Nick |
| Author: | nickschlemer [ Thu Apr 17, 2008 1:41 pm ] |
| Post subject: | |
Anyone?? |
| Author: | D. Marks [ Thu Apr 17, 2008 1:44 pm ] |
| Post subject: | |
I mounted the back of mine on the floor and the front on a bar to raise it a little. |
| Author: | Bad Influence [ Thu Apr 17, 2008 2:00 pm ] |
| Post subject: | |
Mine are mounted on an angled piece of aluminum. Wish they leaned back a little more than they do. |
| Author: | bevans37095 [ Thu Apr 17, 2008 2:11 pm ] |
| Post subject: | |
I have suspension seats and raised the front about 2 inches. It's much more comfortable that way. |
| Author: | Buckmaster [ Thu Apr 17, 2008 2:47 pm ] |
| Post subject: | |
Tim at Southern buggys might have the angled aluminum plates in stock to mount your seat on an angle.His # is 606-864-2217. |
| Author: | Roy [ Thu Apr 17, 2008 4:17 pm ] |
| Post subject: | |
I also have suspension seats and my front mounts are 2.5" higher than the rear. PS: NICK, you need to get out on a ride and check out some buggies in person and take some mental notes. Come to Wellsville in 4 weeks for the party and check out everyones rides. Take pictures, steal ideas. |
| Author: | Kyle [ Thu Apr 17, 2008 4:30 pm ] |
| Post subject: | |
Roy wrote: Take pictures, steal ideas.
hey Roy its borrow not steal hahah |
| Author: | MickeyMouse [ Thu Apr 17, 2008 7:21 pm ] |
| Post subject: | |
I have done this two ways. When my floor was on top of the frame, I put a small 2x4 under the front mounts of each seat. Cheap solution and simple solution. On my new buggy, I have the floor under the frame so I mounted front tabs flush with the top of the frame and the back tabs flush with the floor. I also used the seat mounts and seat adjusters from Summit Racing. Good Luck. Dan |
| Author: | buggy66 [ Thu Apr 17, 2008 9:48 pm ] |
| Post subject: | |
I have suspesion seats and they are leaned back by a total of 4.5 inches in the front. |
| Author: | hillaholic [ Fri Apr 18, 2008 8:54 am ] |
| Post subject: | |
Here is the front mount from my old rail. They are about 3" raised in the front. I really didn’t like them after a couple hours riding my lower back would start hurting because they were leaned to far back causing you to slide forward and no support on the lower back.
I will have pictures of the seats I got from you(I think it was you) soon. I actually cut the back brackets off and welded them flat and it leand them back about 1" |
| Author: | nickschlemer [ Fri Apr 18, 2008 12:25 pm ] |
| Post subject: | |
hillaholic wrote: Here is the front mount from my old rail. They are about 3" raised in the front. I really didn’t like them after a couple hours riding my lower back would start hurting because they were leaned to far back causing you to slide forward and no support on the lower back.
![]() I will have pictures of the seats I got from you(I think it was you) soon. I actually cut the back brackets off and welded them flat and it leand them back about 1" How would you slide forward if they were leaned back? Reason i ask i really need these as comfortable as possible due to lower back disc problems. I would think that if the front was raised you would slide back into the seat and it would support your back even better.. |
| Author: | hillaholic [ Fri Apr 18, 2008 1:15 pm ] |
| Post subject: | |
nickschlemer wrote: How would you slide forward if they were leaned back? Reason i ask i really need these as comfortable as possible due to lower back disc problems. I would think that if the front was raised you would slide back into the seat and it would support your back even better..
I didn’t slide far maybe an inch. I don’t know, I thought the same thing when I put them in. They were the all vinyl Corbeau seats and I leaned them for a little more head room. They felt great when I was all strapped in with the 5point harnesses and not driving but after an hour or so of driving my lower back would start aching. I could have been my pedals too low or just a little far away causing me to stretch to reach them. I tried moving my pedals back an inch it did help a little, but if I moved them any further back my knees would be to close to the steering wheel. What I think it was doing was pushing up on my thighs to much and making me slide on the vinyl. |
