Tire Grinding.
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=361
Author:  D. Marks [ Thu Apr 26, 2007 1:45 pm ]
Post subject:  Tire Grinding.
I thought I had run out of rubber to cut off my Boggers, but no.I found more. I started cutting with the knife till the blade broke off. Then I switched to the grinder. The grinder works fast but it's messy and I'm guessing the smoke is toxic. The sidewalls are much softer though.
Author:  kybuggy1 [ Thu Apr 26, 2007 4:56 pm ]
Dean, where can you get those discs? I bought one similiar off the Mac truck, but that one looks like it would work alot faster with the holes in it to sling the debris.
Also does it fit a 4"grinder (small arbor) or 4 1/2". Got both, but the 4 1/2" is a lot better grinder. My disc only fits the 4". Yours looks like 4 1/2" in the pic.
Thanks, Larry
Author:  Roy [ Thu Apr 26, 2007 6:57 pm ]
I'm calling Mike Rowe and put you on "Dirty Jobs".
:twisted:
Author:  FOX SHOX [ Thu Apr 26, 2007 8:56 pm ]
Hey Dean, will those tires still be DOT legal?? I have some Kelly's that I would like to cut but still run on the road. Thanks Dave T
Author:  bruce 1 [ Thu Apr 26, 2007 10:06 pm ]
http://www.alltiresupply.com/p-RH-114.html
This is a good place to order the Tire Rasps from they have all kinds. This type is the best. It is called a rubber hog by rema. I also took a drill and made the hole a little bit bigger so it would fit my grinder. The 2 1/2" works best for tractor tires it will get between the bars. I have tried the 4" and they dont do as good of a job for me. These things are very dangerous also, They will cut your flesh as well as rubber! So use extream caution.
:eek: [/img][/list][/list][/code]
Author:  kybuggy1 [ Fri Apr 27, 2007 12:49 am ]
Thanks,Bruce.
That place has alot of other useful stuff, too.
Author:  billykissell [ Fri May 18, 2007 10:11 am ]
http://www.performancebodies.com/store/ ... %5Fid=1710
i have read that the monster truck builders use a "ginsu" knife blade mounted in a sawzall.
