| 6 rib and 1641 http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=3007 |
| Author: | rollingrock [ Sun Feb 10, 2008 4:52 pm ] |
| Post subject: | 6 rib and 1641 |
i am being told repeatedly to get rid of my 6 rib and run a 3 rib, my motor is a 1641, i like the way it runs and it is lasting a really long time, but i cant crawl up nything, i have to have a lot of wheel speed and keep it goin, im wondering if a 3 rib would make the change im being told it will, so i can just tractor up hills, p.s. i only have a progressive weber on the bug, i was thinking bout just improving carbs this year and leave the 6 rib in, what do u think,anybody? |
| Author: | purplerail [ Sun Feb 10, 2008 5:11 pm ] |
| Post subject: | |
a 3 rib would be the most cost effective fix then you can lug around buy you a 3 rib and save your 6 fo upgrade time |
| Author: | volksdude2007 [ Sun Feb 10, 2008 5:36 pm ] |
| Post subject: | |
i have a 5 rib in my buggy and when i had a 1641 in it with stock cam and flywheel well everything except the p/c i could creep up over allot of hills but my cousin had a 3 rib in his buggy with a 1641 and he loved it |
| Author: | dunebuggy79 [ Sun Feb 10, 2008 6:22 pm ] |
| Post subject: | |
You definitely need a 3 rib with a motor that small a six rib is good for motors above 2000cc. aaron |
| Author: | Stevo [ Sun Feb 10, 2008 7:30 pm ] |
| Post subject: | |
Trade ya a 3 rib for your six rib!! |
| Author: | Odyknuck [ Sun Feb 10, 2008 8:02 pm ] |
| Post subject: | |
Hers a three rib for $250.00 on The Samba: http://www.thesamba.com/vw/classifieds/ ... ?id=561571 |
| Author: | purplecoffin [ Sun Feb 10, 2008 11:59 pm ] |
| Post subject: | 3 rib |
PM sent |
| Author: | CrazyD [ Tue Feb 12, 2008 12:39 am ] |
| Post subject: | |
iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio |
| Author: | Baddvw [ Tue Feb 12, 2008 1:26 am ] |
| Post subject: | |
[quote='CrazyD']iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio[/quote] What size rear tires are you running? |
| Author: | CrazyD [ Tue Feb 12, 2008 11:50 am ] |
| Post subject: | |
[quote='Baddvw'][quote='CrazyD']iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio[/quote] What size rear tires are you running?[/quote] iam running 29 10.50 15 size tires they arent huge but gets the job done. the tread pattern is like that of a tractor tire.i have been through some ponds,hill climbs and some mud runs they seem to work well. also it seems to keep me geared pretty low wich i lik |
