It is currently Mon May 04, 2026 5:56 am
 Post subject: 6 rib and 1641
PostPosted: Sun Feb 10, 2008 4:52 pm
i am being told repeatedly to get rid of my 6 rib and run a 3 rib, my motor is a 1641, i like the way it runs and it is lasting a really long time, but i cant crawl up nything, i have to have a lot of wheel speed and keep it goin, im wondering if a 3 rib would make the change im being told it will, so i can just tractor up hills, p.s. i only have a progressive weber on the bug, i was thinking bout just improving carbs this year and leave the 6 rib in, what do u think,anybody?
PostPosted: Sun Feb 10, 2008 5:11 pm
a 3 rib would be the most cost effective fix then you can lug around buy you a 3 rib and save your 6 fo upgrade time
PostPosted: Sun Feb 10, 2008 5:36 pm
i have a 5 rib in my buggy and when i had a 1641 in it with stock cam and flywheel well everything except the p/c i could creep up over allot of hills but my cousin had a 3 rib in his buggy with a 1641 and he loved it
PostPosted: Sun Feb 10, 2008 6:22 pm
You definitely need a 3 rib with a motor that small a six rib is good for motors above 2000cc.
aaron
PostPosted: Sun Feb 10, 2008 7:30 pm
Trade ya a 3 rib for your six rib!!
PostPosted: Sun Feb 10, 2008 8:02 pm
Hers a three rib for $250.00 on The Samba:
http://www.thesamba.com/vw/classifieds/ ... ?id=561571
 Post subject: 3 rib
PostPosted: Sun Feb 10, 2008 11:59 pm
PM sent
PostPosted: Tue Feb 12, 2008 12:39 am
iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio
RIDE HARD-PARTY HARDER
PostPosted: Tue Feb 12, 2008 1:26 am
[quote='CrazyD']iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio[/quote]
What size rear tires are you running?
PostPosted: Tue Feb 12, 2008 11:50 am
[quote='Baddvw'][quote='CrazyD']iam running a 3 rib trans on my buggy powered by a ford 2.3 and iam very pleased with the lower gear ratio[/quote]
What size rear tires are you running?[/quote]
iam running 29 10.50 15 size tires they arent huge but gets the job done.
the tread pattern is like that of a tractor tire.i have been through some ponds,hill climbs and some mud runs they seem to work well.
also it seems to keep me geared pretty low wich i lik
