| another qustion rear suspention http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=2458 |
Page 1 of 2 |
| Author: | tanner2803 [ Wed Dec 26, 2007 7:19 pm ] |
| Post subject: | another qustion rear suspention |
thanxs for all the help and patience my next question is what should i do for rear suspension as in coil over or torsion and 2x3 3x3 3x5 im running a subie 2.2 and plan to hill climb and drive thanxs |
| Author: | Firebug [ Wed Dec 26, 2007 7:23 pm ] |
| Post subject: | |
When I went to the 2.2 I lost a little ground clearance and gained a little weight. Build your arms as big as you can afford and go with airbags. The bags are lighter, cheaper, and adjustable from the seat. That's my story and I'm sticking to it. |
| Author: | Roy [ Wed Dec 26, 2007 9:31 pm ] |
| Post subject: | |
3x5 arms with coil overs will give you the best overall performance AND tune ability. Definitely use the 3x5's with the subie motor. If you don't, your front end will not stay down and it will not climb steep hills. |
| Author: | bruce 1 [ Wed Dec 26, 2007 9:39 pm ] |
| Post subject: | |
what roy said 10-4 |
| Author: | rockrockets1 [ Wed Dec 26, 2007 10:15 pm ] |
| Post subject: | |
I'll have to go with Firebug I have coilovers on my buggy now the springs wear out .Plus it's hard to get the right rate you can spend a bunch of money on springs . I'm trying to go air bag now |
| Author: | Firebug [ Wed Dec 26, 2007 10:16 pm ] |
| Post subject: | |
If I can do it , anybody can... |
| Author: | tanner2803 [ Thu Dec 27, 2007 12:56 pm ] |
| Post subject: | |
ok i think im going to go with airbags for now and 2x3 arms till i have the money to go bigger and go to 930's so now i guess i need someone to help point me in the right direction for an airbag system. thanxs for all yals help |
| Author: | Roy [ Thu Dec 27, 2007 5:11 pm ] |
| Post subject: | |
There are lots of guys on here that run air bags. I am sure you will get plenty of advice. |
| Author: | Firebug [ Thu Dec 27, 2007 8:40 pm ] |
| Post subject: | |
Here are bags and a kit on ebay. It will give you an idea what you need . Seems like I found similar items at JC Whitney and Summitt racing. There are some other online companies as well. The bags you use may depend on the room you have to work with. I used the size next smaller but when I upgrade I may use these. http://cgi.ebay.com/ebaymotors/Fireston ... enameZWDVW http://cgi.ebay.com/ebaymotors/Ride-Rit ... enameZWD1V |
| Author: | harleyhunter05 [ Thu Dec 27, 2007 9:32 pm ] |
| Post subject: | |
can someone post pics of how to mount them in--thinkin about them for my 4 seater. And how do u set tension on rear torsion(soft--stiff) when u use airbags----thanks |
| Author: | Firebug [ Thu Dec 27, 2007 10:09 pm ] |
| Post subject: | |
| Author: | kendel [ Fri Dec 28, 2007 2:37 am ] |
| Post subject: | |
[quote='Firebug']http://forum.woodsbuggy.com/privmsg.php?folder=sentbox&mode=read&p=8833[/quote] why is my sent box showing up in you post |
| Author: | ky-bc [ Fri Dec 28, 2007 9:35 am ] |
| Post subject: | |
[quote='kendel'][quote='Firebug']http://forum.woodsbuggy.com/privmsg.php?folder=sentbox&mode=read&p=8833[/quote] why is my sent box showing up in you post hey firebug, are you a hacker... |
| Author: | Roy [ Fri Dec 28, 2007 10:19 am ] |
| Post subject: | |
[quote='harleyhunter05']can someone post pics of how to mount them in--thinkin about them for my 4 seater. And how do u set tension on rear torsion(soft--stiff) when u use airbags----thanks[/quote] When you use air bags, you remove the torsion bars and sell them to somebody. The bag itself is now the spring that holds the buggy up. |
| Author: | Firebug [ Fri Dec 28, 2007 10:21 am ] |
| Post subject: | |
I had sent those pics to Kendel and just copied and pasted . Is this causing a problem,,,,I will stop doing it that way. |
| Author: | Firebug [ Fri Dec 28, 2007 10:25 am ] |
| Post subject: | |
Also when I installed I kept the torsion bars,,,just relaxed them,, slid them straight in with no pre stress ,This left in some weight but it gave me a sorta progressive spring rate. In other words the torsion bars aren't doing much until extreme travel then they kick in . I was told this is not necessary and may even be a bad thing to do but I haven't noticed any adverse effects...I may remove them when I upgrade. |
| Author: | Firebug [ Sun Dec 30, 2007 3:05 am ] |
| Post subject: | |
I just read that the bags do not require bumpstops,,,cool |
| Author: | D. Marks [ Sun Dec 30, 2007 6:14 am ] |
| Post subject: | |
I couldn't find a better pic but you can see in this pic the plates I used to get rid of torsion bars when I went to coil overs.
| Author: | kendel [ Sun Dec 30, 2007 7:09 pm ] |
| Post subject: | |
what rate springs did you end up with |
| Author: | Firebug [ Sun Dec 30, 2007 7:44 pm ] |
| Post subject: | |
Skidz,,I would like to see that up close. I need that setup on my buggy. |
| Author: | MadMike [ Sun Dec 30, 2007 10:32 pm ] |
| Post subject: | |
This is how I did mine
| Author: | pipedope [ Sun Dec 30, 2007 10:33 pm ] |
| Post subject: | |
were did u get a set like that mike |
| Author: | MadMike [ Sun Dec 30, 2007 10:44 pm ] |
| Post subject: | |
All home built. |
| Author: | Firebug [ Sun Dec 30, 2007 10:49 pm ] |
| Post subject: | |
M&M you are good. |
| Author: | Stevo [ Sun Dec 30, 2007 10:55 pm ] |
| Post subject: | |
Looks like another fine product of M&M Fab and Machine Inc. |
