It is currently Mon May 04, 2026 8:06 pm
 Post subject: air compresor qustion
PostPosted: Wed Jan 16, 2008 7:35 pm
ok.. i am plannign to run air bags in the rear
i have a subie for power plant
if i leave the airconditioning on can i put an airfilter on the intake side and a T with a pop off valve and the other side of the T go to a small 3 gallon tank with a one way valve in the line
would this be enough to run my air bags off
thanxs for all t he help
 Post subject: bags
PostPosted: Wed Jan 16, 2008 10:23 pm
firebug what know the answer to that
PostPosted: Wed Jan 16, 2008 10:25 pm
plenty
PostPosted: Wed Jan 16, 2008 10:59 pm
run the intake side to the air cleaner, the pressure side to the tank with a pressure valve from an air compressor. the electric swith from air compressor to turn on the clutch. You will also need to drill and tap a plug on the side of compressor and put a grease fitting in it to grease lightly. It will work for a long time
PostPosted: Wed Jan 16, 2008 11:08 pm
I thought about doing that but opted for the easy way out with a dc compressor. About the same weight but the dc is slower I'm sure. Good luck tanner.
PostPosted: Wed Jan 16, 2008 11:13 pm
ok well then im putign it back on the motor lol
