It is currently Mon May 04, 2026 7:41 pm
PostPosted: Sun Dec 16, 2007 11:44 pm
http://pirate4x4.com/productreviews/staun/index.php
http://www.staunproducts.com/
I'm thinking about getting a set of these to try on my baja whenever I get it going. What do you guys think?
John
PostPosted: Sun Dec 16, 2007 11:50 pm
A buddy of mine runs them on his samurai on all 4 wheels, and he loves them!, he can almost run them around 5 psi, and the tires look flat, but cannot get them to pop off of the beads. a little pricey though.
PostPosted: Mon Dec 17, 2007 10:28 pm
they work good but i wouldn't recomend them on a woodsbuggy. staun advertises that you can run them with a flat tire, can't do it with a v-bar tire there just to wide. flat tire's are a p.i.a. because you have to be careful not to injure the staun innertube when breaking the bead. this can be tough out on the trail and it's just one more think to f*** with. i ran them for 11/2 seasons. ended up buying a set of beadlock rims, i run tubes so patching or replacing is quick and easy. remove tire, unbolt beadlock, remove tube and repair, reinstall. no bead to break for repairs.
i think there more suited for wheelers(sammys,jeeps,ect....)
if your still intrested i have a set that i will sell at a good price p.m. me
- Sigmund Freud
- Antonio Meloni
