| What type of Shifters do you guys run or like? http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=2204 |
| Author: | BUGGYMAN [ Sun Dec 09, 2007 5:19 pm ] |
| Post subject: | What type of Shifters do you guys run or like? |
Just wondering, I never hear what type of shifters you guys run or like to run. I have seen many different types, used them all from stock, to homemade to bugpack, and I like the short throw T style from Bugpack. Although, I haven't used a Berg, just wondering what type you guys like to run? Let me know, thanks Donnie |
| Author: | Buckmaster [ Sun Dec 09, 2007 5:38 pm ] |
| Post subject: | |
When i had a rail i prefered a Scat,good reverse lockout.Like my opinion matters,but it will here soon |
| Author: | Eric DeBord [ Sun Dec 09, 2007 6:33 pm ] |
| Post subject: | |
Scat too close for me. Gene Berg is good, but you have to take out a loan to buy one(I think 350.00 plus). I use a modified stock shifter..works great. |
| Author: | GAMNTRAIL [ Sun Dec 09, 2007 7:25 pm ] |
| Post subject: | |
I use a stock shifter that is cut down, so it;s only about 4" high. Works great for me |
| Author: | Kyle Martin [ Sun Dec 09, 2007 8:41 pm ] |
| Post subject: | |
For the past couple seasons I've had the "short" empi T-handle shifter with the push button reverse lockout. The shifts are always solid, and I never have problems hitting the gears. One thing I have come to find out about it though is once in a while you have to take a brillo pad and shine the button up and coat it with some light oil to make it work smoothly. The button is aluminum as is the body, and they tend to oxidize/corrode lightly if you don't stay on top of it. |
| Author: | volksdude2007 [ Sun Dec 09, 2007 9:10 pm ] |
| Post subject: | |
i use the empi short handle t shifter personally i do not like it i would like to get the bug pack or empi shifter with the pull lever for reverse |
| Author: | pipedope [ Sun Dec 09, 2007 9:33 pm ] |
| Post subject: | shifter |
I use a empi trigger style shifter so far i like well. had a scat shifter and hated it . |
| Author: | frankenbuggy06 [ Sun Dec 09, 2007 10:00 pm ] |
| Post subject: | |
stock with an 8 ball shifter knob. had a bugpack t shifter. was hitting mah lag. ill sell it if anyone wants it |
| Author: | purplerail [ Sun Dec 09, 2007 10:45 pm ] |
| Post subject: | |
had a hurst and empi trigger but stock worked the best in mine |
| Author: | bruce 1 [ Sun Dec 09, 2007 11:32 pm ] |
| Post subject: | |
Scat |
| Author: | Odyknuck [ Mon Dec 10, 2007 9:39 am ] |
| Post subject: | |
frankenbuggy06, How much do you want for the shifter. How used is it? Is the 10" or the 12" |
| Author: | Baddvw [ Mon Dec 10, 2007 11:54 am ] |
| Post subject: | |
I use a Scat Fast Drag shifter, Straight handled. |
| Author: | D. Marks [ Mon Dec 10, 2007 12:15 pm ] |
| Post subject: | |
Empi trigger style |
| Author: | Baddvw [ Mon Dec 10, 2007 12:30 pm ] |
| Post subject: | |
[quote='Eric DeBord']Scat too close for me. Gene Berg is good, but you have to take out a loan to buy one(I think 350.00 plus). I use a modified stock shifter..works great.[/quote] Hey Eric how good is the Gene Berg shifter? I might check it out. |
| Author: | turboblue [ Mon Dec 10, 2007 4:16 pm ] |
| Post subject: | |
[quote='Baddvw'][quote='Eric DeBord']Scat too close for me. Gene Berg is good, but you have to take out a loan to buy one(I think 350.00 plus). I use a modified stock shifter..works great.[/quote] Hey Eric how good is the Gene Berg shifter? I might check it out.[/quote] Best there is, got a Berg in my 67 Beetle. Was in the bug when I bought it......... Went with a Berg copy in my woods buggy, works great. Took a Scat out and replaced it with th |
| Author: | Eric DeBord [ Mon Dec 10, 2007 4:29 pm ] |
| Post subject: | |
[quote='Baddvw'][quote='Eric DeBord']Scat too close for me. Gene Berg is good, but you have to take out a loan to buy one(I think 350.00 plus). I use a modified stock shifter..works great.[/quote] Hey Eric how good is the Gene Berg shifter? I might check it out.[/quote] Yes, they are good. Solid, positive shifting and the throw is excellent. Just make sure you get the one with the off-road conversion (It has a seal around the button). Thick steel and you wi |
| Author: | Griffin [ Mon Dec 10, 2007 11:21 pm ] |
| Post subject: | |
I had an old empi shifter in my rail to start with and ended up swaping a factory shifter with a quickshift kit into it. John |
| Author: | Roy [ Wed Dec 12, 2007 10:30 am ] |
| Post subject: | |
I use a stock one that has been shortened. Works perfect. I wouldn't use anything else. |
