| Any ideas http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=2164 |
| Author: | Railboy [ Thu Dec 06, 2007 8:06 pm ] |
| Post subject: | Any ideas |
Hey all I still hang around here from time to time. |
| Author: | tntchitwood [ Thu Dec 06, 2007 8:33 pm ] |
| Post subject: | |
Have you checked for condensation in your distributor? Maybe cracked. Good luck |
| Author: | Railboy [ Thu Dec 06, 2007 8:46 pm ] |
| Post subject: | |
yes I checked everything many times and before any says heat tubes let me say it is a trimill exhaust so no ports there. A few years back I had a stocker with a progressive carb done the same thing and I ended up takin old stock heat tubes cut them down turn upside down weld them where your stock ones should be and drilled them and fabbed some other shit it seemed to work. But the idf is off centered and can not find correct size tubes to fit that intake Without butchering things up. |
| Author: | fgrir [ Thu Dec 06, 2007 10:14 pm ] |
| Post subject: | |
Mine has always done the same thing. Single dell w/tri mill, no heat tubes. Will not run worth a damn in cold weather. |
