| painting my buggy http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=2125 |
| Author: | jesse [ Tue Dec 04, 2007 1:55 am ] |
| Post subject: | painting my buggy |
will spray paint work and stick good on the frame. and is there a certain brand or type that will work better |
| Author: | wildwillie [ Tue Dec 04, 2007 2:01 am ] |
| Post subject: | |
krylon is good it drys fast make sure you us clare coat mine turned out killer |
| Author: | jesse [ Tue Dec 04, 2007 2:06 am ] |
| Post subject: | |
ok thanks for the help.. i did it with high heat engine paint last time and no clear and it did not last long |
| Author: | BUGGYMAN [ Tue Dec 04, 2007 4:00 am ] |
| Post subject: | painting your buggy |
If your just gonna to touch it up that would work, but if your gonna strip off all the old paint and then paint it, I would guess it would take 15-20 cans, and at $4 a can, that would be $80. I bought a gallon of AC orange at tractor supply, the paint, thinner, and everything was on 72 dollars and it turned out great! I shot it with a paint gun and couldn't be any happier with it. Actually, didn't have much of that gallon left when I was done, as you waist about 75% when you are painting 1.5 tubes. Donnie |
| Author: | showngo [ Tue Dec 04, 2007 4:15 pm ] |
| Post subject: | |
Im new to the site but would like to say I used eengine enamal on mine but the key is to sand good.then use good sanable primer at autozone.Mine is goin on 2 years now. |
| Author: | Odyknuck [ Tue Dec 04, 2007 4:29 pm ] |
| Post subject: | |
I have found that in order for High temp engine paint to work it needs to be heat cured like an engine would do normally. I use a Heat lamp and or Heat guns to cure it. It holds up well when you do it otherwise it does not last. |
