It is currently Sun May 03, 2026 7:56 pm
 Post subject: painting my buggy
PostPosted: Tue Dec 04, 2007 1:55 am
will spray paint work and stick good on the frame. and is there a certain brand or type that will work better
PostPosted: Tue Dec 04, 2007 2:01 am
krylon is good it drys fast make sure you us clare coat mine turned out killer
PostPosted: Tue Dec 04, 2007 2:06 am
ok thanks for the help.. i did it with high heat engine paint last time and no clear and it did not last long
 Post subject: painting your buggy
PostPosted: Tue Dec 04, 2007 4:00 am
If your just gonna to touch it up that would work, but if your gonna strip off all the old paint and then paint it, I would guess it would take 15-20 cans, and at $4 a can, that would be $80. I bought a gallon of AC orange at tractor supply, the paint, thinner, and everything was on 72 dollars and it turned out great! I shot it with a paint gun and couldn't be any happier with it. Actually, didn't have much of that gallon left when I was done, as you waist about 75% when you are painting 1.5 tubes.
Donnie
PostPosted: Tue Dec 04, 2007 4:15 pm
Im new to the site but would like to say I used eengine enamal on mine but the key is to sand good.then use good sanable primer at autozone.Mine is goin on 2 years now.
PostPosted: Tue Dec 04, 2007 4:29 pm
I have found that in order for High temp engine paint to work it needs to be heat cured like an engine would do normally. I use a Heat lamp and or Heat guns to cure it. It holds up well when you do it otherwise it does not last.
