Woodsbugg vs RZR Technical Riding
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=17539
Page 1 of 2
Author:  TheOriginalOne [ Sun Dec 21, 2014 8:53 pm ]
Post subject:  Woodsbugg vs RZR Technical Riding
Hey guys im going to build a buggy very soon, ive been looking at videos of technical riding, didnt see a lot of woodsbuggy but sure did see RZR,
They seem to pass about everywhere in the videos. Would a buggy be able to follow them? I know the RZR are 50" width and buggies 70" around.
I am asking this question because since very few people have buggies here, i will be riding with RZR and quads and my buddies who have dirtbikes. I also love technical woods riding, i would just hate not being able to go to places because im too wide!
Also to have the right to go in ATV trails i need to be 60" wide max. But i also want the highest ground clearance!
Thanks guys, lets hear what yall have to say!
Sent from my Nexus 5 using Tapatalk
Author:  darrell [ Mon Dec 22, 2014 10:16 am ]
Post subject:  Re: Woodsbugg vs RZR Technical Riding
Most of your woods buggys are 80 +++ I got both and love them both but i feel if the buggy has the room it would go where the rzr won't go ..They both got there place in the woods that's for sure .
Author:  MickeyMouse [ Mon Dec 22, 2014 10:30 am ]
Both SxS and Buggies are a lot of fun. However, they are very different. In my opinion, the largest difference is that the SxS has 4 wheel drive.
Since the SxS buggies are smaller, they are going to be able to get through tight trails faster than a buggy.
On the other hand, buggies have larger tires, longer wheelbase and more power, so bumps and steep hills will be easier in a buggy.
If the places you want to ride has a width limitation, you CAN NOT build a buggy with a 50 or 60 inch Width.
Author:  jesse [ Mon Dec 22, 2014 10:35 am ]
Sounds like for all the things you wanna do you need a rzr not. A buggy get a rzr put a aftermarket cage and seat belts and enjoy
Author:  TheOriginalOne [ Mon Dec 22, 2014 10:49 am ]
Alright thanks, makes sense! for the width limitation that is not a big problem but its 60" max.
yeah maby it would be better, but i really want to build one, and if anything il have to go to other trails than the one near my house, also can i drive this thing during winter? in the atv snow trails? or would it not go good. like traction issues because rwd.
thanks!
alright, yeah ive seen a lot of vids that the SXS roll over since they are very not wide and long. 80"inch is pretty wide the perfect width for me would be 68-70". Thanks!
Author:  TheOriginalOne [ Mon Dec 22, 2014 11:24 am ]
if i want less width but more ground clearance, i go with stock rear arms with 930 axles? thats going to save 6inches from 3x3 arms?
thanks!
Author:  RD-GLIDER [ Mon Dec 22, 2014 11:57 am ]
We tend roll a buggy now and then as well just takes a little more effort.
Author:  TheOriginalOne [ Mon Dec 22, 2014 1:17 pm ]
sorry i didnt quite understand that?
thanks
Author:  RD-GLIDER [ Mon Dec 22, 2014 2:36 pm ]
I just meant you can turn a wide rail over even with +5 arms. Done it . There's lots of places my rail don't squeeze through.
Author:  TheOriginalOne [ Mon Dec 22, 2014 2:39 pm ]
Alright so maby i would be better off with stock width arms, and about ground height is therea big difference between stock and 3x3 or 0x3(if that exists)
Thankss!!
Author:  RD-GLIDER [ Mon Dec 22, 2014 6:19 pm ]
I think narrow limits height with cv axles.. They only have so much angle.
Author:  jesse [ Mon Dec 22, 2014 6:41 pm ]
Stock is junk at least go 3x3 get a lot of your ground clearance from your arms
Author:  Buckmaster [ Mon Dec 22, 2014 7:25 pm ]
I go where i want in a buggy. If your trailriding,thereis always a way around an obstacle,plus what fun would it be just riding a wide open trail. Build a buggy and drive it like you stole it.
Author:  TheOriginalOne [ Mon Dec 22, 2014 7:31 pm ]
Yeah, the only reason i was debating wether or not to build one is because i have a dirtbike already and that the rail would be pretty wide, i made my mind and im going to build it. Im going to buy a rig with all the parts i want and just put it on my single seater frame.
- the only problem i see is that the tranny is nose shift and i would need a side shift, il have to make that work!
thanks guys
Author:  jesse [ Tue Dec 23, 2014 8:02 am ]
Why do you need a side shift most people run nose shift
Author:  TheOriginalOne [ Tue Dec 23, 2014 10:15 am ]
Because my frame is a single seater, i may be wrong but this is what i have read, if i can use a nose shift im going to be happy.
Thanks
Author:  Pettigo [ Tue Dec 23, 2014 11:53 am ]
You can use nose shift. You will be happier with a rzr. If that's what your friends have. You will not have to work on it as much. But good luck , like I have said before.
Author:  TheOriginalOne [ Tue Dec 23, 2014 12:02 pm ]
Alright and no my friends have dirtbikes, but if it gets boring for them or me il find people with quads and rzr, im dead set i want a buggy! You have a single seater right pettigo?
Author:  Pettigo [ Tue Dec 23, 2014 12:04 pm ]
4 seater and yes I'm building a ss
Author:  TheOriginalOne [ Tue Dec 23, 2014 12:09 pm ]
Cool!, why do you insist that i buy a rzr instead? because it will be less maintenance? the only problem i see is the buggy being to wide, thats the only thing im scared of.
thanks
Author:  jesse [ Tue Dec 23, 2014 12:21 pm ]
You can use a nose shift in a single seater have one in mine and most people do you just have to build your shifting rod back to it right
Author:  TheOriginalOne [ Tue Dec 23, 2014 12:23 pm ]
Great! Thanks
Author:  Pettigo [ Tue Dec 23, 2014 12:24 pm ]
I just don't want you to put a lot of money in it and quit. They are$$ to get a dependable buggy. You need to be mechanically inclined. You can learn a lot here on woodsbuggy. You would have been better off to buy one already going. That way you would know exactly in a seasons ride, what you wanted to change on your buggy. Imo your going in it blind , just hate to see people waste money and lots of time. You can do it and a buggy is lots of fun . Enjoy. I've been working on my one seater for 2 years and still not finished. It's the little stuff that adds up$$
Author:  TheOriginalOne [ Tue Dec 23, 2014 12:34 pm ]
Yeah i know thats why i was debating whether or not to buy/build one, my current intion was buying a already running 2 seater with all the good stuff (5rib,1915,3x3 arms, link pin with 4x1 arms, fox shocks all around, 930cvs.. Ect ect for 5k)
Right now i got time on my hands to build it, to be honest i wasnt sure if wanted one or not for a long time, but there are trails here which are perfect for my dirbike and then big open atv trails which i would be able to go with a buggy, another good reason is because i love building and modding, adding stuff, electronics ect. Also here we have winters with lots of snow, so we i would ride with it during the winter. But yes its going to be expensive but hey whats cheap these days!
Thanks!
Author:  Pettigo [ Tue Dec 23, 2014 12:38 pm ]
Good luck
