It is currently Mon May 04, 2026 1:31 am
 Post subject: Trashed my 1641....
PostPosted: Mon Oct 29, 2007 5:24 am
So as some of you know i was having troubles with my engine down at wellsville, at one point we even thought it tossed a rod. Turns out that my flywheel came loose, which in turn louvered out the dowel pin holes beyond belief. I haven't split the case yet, but im assumming it trashed the case when it through the motor out of balance... We'll see. In the meantime i would like to find another shortblock of some sort. I only have 2 rides on this motor and both times it didnt run right. Definately sucks!
PostPosted: Mon Oct 29, 2007 6:18 am
Don't let this get you discouraged. Use it as a lesson learned. Every VW motor must have the gland nut very tight. Always use red Locktite when installing the flywheel nut. If you get a used engine, remove the flywheel before you use it and reinstall it with locktite.
R
PostPosted: Mon Oct 29, 2007 7:46 am
yeah, i understand, i look at this all as a learning curve, we've all been there. I torqued it down to 220 or so ft lbs and assumed it good but now i know and will make sure not to make this mistake again. I'll have a motor back together as soon as i can.
PostPosted: Mon Oct 29, 2007 8:50 am
Jeff if you need a another crank I have a stock one for the price of shipping.
Steve
216-695-0733
PostPosted: Mon Oct 29, 2007 10:10 am
my self i never use a used gland nut if i take one lose i use a new one with a lot of lock t.
PostPosted: Mon Oct 29, 2007 10:13 am
it was a brand new cb performance gland nut. Odyknuck ill keep that in mind, i havent pulled it apart yet, i fear the thrust bore is going to be trashed.
PostPosted: Mon Oct 29, 2007 11:19 am
i did the same thing last winter. i havent rebuilt it yet but im putting a 74 crank in it
PostPosted: Mon Oct 29, 2007 5:39 pm
put a subaru in it for less money and more power, right madmike? I might be selling a 2077 turn key. will let you know
PostPosted: Mon Oct 29, 2007 5:54 pm
Subaru's are wicked. :evil:
PostPosted: Mon Oct 29, 2007 8:35 pm
[quote='JeffClay']it was a brand new cb performance gland nut. Odyknuck ill keep that in mind, i havent pulled it apart yet, i fear the thrust bore is going to be trashed.[/quote]if its like the scat nut you can torque it to 360 lbs or so. plus you need to have it drilled to 8 dowels.
PostPosted: Mon Oct 29, 2007 8:54 pm
[quote='Stevo']put a subaru in it for less money and more power, right madmike? I might be selling a 2077 turn key. will let you know[/quote]
That's right............ And Jeff, that's a fine running 2077.
PostPosted: Tue Oct 30, 2007 5:18 am
Were going to check out the motor today and see if we can save it, if we can drill it out to 8 dowels were going to try. we shall see...
PostPosted: Tue Oct 30, 2007 5:19 pm
Hill Climber
Jeff, Roy is right don't get dicouraged. I made ALOT of mistakes but I learned from them. You will learn alot before you get it right. I did. You seem like a sharp guy and you will have a short learning curve.
On the other hand if you weren't so sharp and you rode the short bus to school you may want to start looking for a place to mount the radiator.
Dean
PostPosted: Tue Oct 30, 2007 7:15 pm
Dean you have cut all of us radiator guy's to the kwick
PostPosted: Tue Oct 30, 2007 7:51 pm
Hill Climber
You'll be alright.
PostPosted: Wed Oct 31, 2007 5:23 am
haha i was thinking about mounting the radiator to my front bumper with ratchet straps, temporarily of course. No, but all radiators aside i did trash the crank, squared out the gland nut hole. Brian (buggyb) that did my transmission is going to rebuild it for me. Im going to pick up a counterweighted crank this time and a set of ratio rockers, also. brian is going to get the compression right in it and really get her pumping.. Probably won't make any more rides this year, but it's on for next spring!!
