It is currently Sun May 03, 2026 3:25 pm
 Post subject: Will this 2.4 work?
PostPosted: Tue Jul 30, 2013 9:01 am
I've searched all morning trying to find an answer. sorry if dumb question but I want to build a water cooled rail.
I can buy a running complete car from a guy at work for dirt cheap. it's a 97 Pontiac sunfire with a 2.4.
I'm trying to figure out if this engine can be used for a rail? I've read that 97 is the earliest motor you can use and that the ecotecs were based off of this motor?
 Post subject: Re: Will this 2.4 work?
PostPosted: Tue Jul 30, 2013 9:53 am
I would think you could use any engine so long as you can connect it to a trans.
I would contact Kennedy engineering to see if they make an adapter plate.
PostPosted: Tue Jul 30, 2013 10:56 am
I was just thinking it was a ecotec motor but I guess ecotec didn't start until 2000. I'll contact Kennedy
PostPosted: Tue Jul 30, 2013 2:07 pm
Ecotec started in 02 ion and all gm in 03 it will work but it's cast iron
PostPosted: Wed Jul 31, 2013 8:10 am
yes it will work. that 2.4 is known as the quad four. it has good power but is a little heavier than the ecotec because it has a cast iron block. nitro mudder on this site has one in his buggy.
PostPosted: Thu Aug 01, 2013 8:45 am
so we'll this quad 4 use the same adapter as the ecotec?
PostPosted: Thu Aug 01, 2013 3:36 pm
Call Kennedy and ask them. More to it than just a plate you also need a flywheel to go with that set up. The crank bolt pattern could be different.
