| Will this 2.4 work? http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=15766 |
| Author: | c.morris740 [ Tue Jul 30, 2013 9:01 am ] |
| Post subject: | Will this 2.4 work? |
I've searched all morning trying to find an answer. sorry if dumb question but I want to build a water cooled rail. I can buy a running complete car from a guy at work for dirt cheap. it's a 97 Pontiac sunfire with a 2.4. I'm trying to figure out if this engine can be used for a rail? I've read that 97 is the earliest motor you can use and that the ecotecs were based off of this motor? |
| Author: | MickeyMouse [ Tue Jul 30, 2013 9:53 am ] |
| Post subject: | Re: Will this 2.4 work? |
I would think you could use any engine so long as you can connect it to a trans. I would contact Kennedy engineering to see if they make an adapter plate. |
| Author: | c.morris740 [ Tue Jul 30, 2013 10:56 am ] |
I was just thinking it was a ecotec motor but I guess ecotec didn't start until 2000. I'll contact Kennedy |
| Author: | bluebuggy [ Tue Jul 30, 2013 2:07 pm ] |
Ecotec started in 02 ion and all gm in 03 it will work but it's cast iron Posted using the WoodsBuggy Mobile App |
| Author: | tw9294 [ Wed Jul 31, 2013 8:10 am ] |
yes it will work. that 2.4 is known as the quad four. it has good power but is a little heavier than the ecotec because it has a cast iron block. nitro mudder on this site has one in his buggy. |
| Author: | c.morris740 [ Thu Aug 01, 2013 8:45 am ] |
so we'll this quad 4 use the same adapter as the ecotec? |
| Author: | MadMike [ Thu Aug 01, 2013 3:36 pm ] |
Call Kennedy and ask them. More to it than just a plate you also need a flywheel to go with that set up. The crank bolt pattern could be different. |
