bent buggy
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=1558
Author:  lacassiere [ Mon Oct 22, 2007 3:44 pm ]
Post subject:  bent buggy
i m considering buying a buggy it was in rollover and the whole back end ins bent way right whats the best fix for that
Author:  Odyknuck [ Mon Oct 22, 2007 3:53 pm ]
With out pictures its hard to say what your best solution will be. If its just the rear cage then straighten or replace the tubing. If the torsion assembly is bent you will have more problems then you care to deal with. To really get it straight it would require a frame shop. It would probably require dissasembly to determined whats bent and be able to put it in a frame jig to get it right. If your getting it for a really good price then consider buying a new or used frame and swap the parts.
Author:  winifredevw [ Mon Oct 22, 2007 8:51 pm ]
Post subject:  Re: bent buggy
[quote='lacassiere']i m considering buying a buggy it was in rollover and the whole back end ins bent way right whats the best fix for that[/quote]
Is it a good frame? (Not some home-made-waterpipe-of-crap) Pictures are worth a thousand...
Author:  lacassiere [ Fri Oct 26, 2007 5:24 pm ]
no i dont have pics but it is a berrien frame i think it looks like a warrior
Author:  winifredevw [ Fri Oct 26, 2007 6:55 pm ]
[quote='Odyknuck']With out pictures its hard to say what your best solution will be. If its just the rear cage then straighten or replace the tubing. If the torsion assembly is bent you will have more problems then you care to deal with. To really get it straight it would require a frame shop. It would probably require dissasembly to determined whats bent and be able to put it in a frame jig to get it right. If your getting it for a really good price then consider buying a new or used frame
Author:  D. Marks [ Fri Oct 26, 2007 8:41 pm ]
I was riding with a guy once and he made THE dummest mistake I have ever seen. I mean you can't imagine how stupid this guy was. Real moron. Anyway he hit me and bent his frame pretty bad. Hit me REAL hard. He put his on a frame machine at a body shop and fixed it.
Author:  m.ralston [ Fri Oct 26, 2007 9:25 pm ]
I'm not even going to ask who it was.
Author:  purplerail [ Fri Oct 26, 2007 10:15 pm ]
suprise it was me. hell of a piece of driving if i say so
Author:  D. Marks [ Sat Oct 27, 2007 3:54 am ]
I would have never said your name.
Dean
Author:  purplerail [ Sat Oct 27, 2007 10:21 am ]
they already guessed in sure
