It is currently Mon May 04, 2026 9:25 pm
PostPosted: Fri Apr 05, 2013 11:03 pm
I have a 1600 eng and I have a new cole and fule pump and spark plugs and we are getting power to the cole but not to the points or nothing like that if y'all can please help me out
PostPosted: Sat Apr 06, 2013 5:51 am
Do you have the wire from the dist hooked to the negative side of the coil ?
PostPosted: Sat Apr 06, 2013 8:55 am
Yes I have new condenser new points and distributor on it
PostPosted: Sat Apr 06, 2013 11:36 am
Read the post "Quick Help" under the AIRCOOLED forum. A few weeks ago he had 2 pages of pain and it turned out to be a bad dist right out of the box. Either the lobes or shaft bushings or bent shaft or something was bad.
PostPosted: Mon Apr 08, 2013 2:09 am
take a pic with cap and rotor off the dist, and how its wired to the coil so we can make sure it all wired right
are you sure the points are set correct?
sounds like its wired up wrong or either the points need to be set, if all that checks out it has to be a faulty part somewhere even if they are all new
PostPosted: Mon Apr 08, 2013 5:56 pm
thanks to everyone it was the distributor on it we swip it out and it fired right up
