It is currently Sun May 03, 2026 12:40 pm
 Post subject: optima warranty
PostPosted: Tue Jan 22, 2013 3:19 pm
Anyone have a red or yellow top optima with a good warranty so I can use the warranty? Both my red and yellow tops are bad and the warranty is expired.
Thanks, Brad 440-225-9063
 Post subject: Re: optima warranty
PostPosted: Tue Jan 22, 2013 3:21 pm
Before you condem them try charging them with 6 volts over night then switch to 12 volts.
PostPosted: Tue Jan 22, 2013 3:24 pm
Try this too:
http://www.hotrod.com/techarticles/gene ... ewall.html
It worked for my red top.
Last edited by fortydegnorth on Tue Jan 22, 2013 4:52 pm, edited 2 times in total.
PostPosted: Tue Jan 22, 2013 3:33 pm
Yeah I did that.
PostPosted: Tue Jan 22, 2013 3:44 pm
I 'll make a call for you Brad. We just got a new one for the drag car, I'll check and see if he will go for it.
PostPosted: Tue Jan 22, 2013 3:50 pm
fortydegnorth wrote:
Try this too:
http://www.hotrod.com/techarticles/gene ... m_battery/
Link doesn't work, I was curious as I have a red top thats bad too..
PostPosted: Tue Jan 22, 2013 3:55 pm
Thanks, Mike
PostPosted: Tue Jan 22, 2013 4:27 pm
Try this too:
Copy and paste the whole link. Your only getting part of it by clinking on the highlighted text.
PostPosted: Tue Jan 22, 2013 4:50 pm
This was the thread that we talked about the charging method. Not sure why the link won't work.
http://www.woodsbuggy.com/index.php?opt ... Itemid=109
Here is the fixed link:
PostPosted: Tue Jan 22, 2013 4:54 pm
When I charged my red top per the instructions in the Hot Rod article, it took about 4 days at a 2 amp charge to get it charged. I would leave it on there for a week and just check it all the time to see if it's getting hot. Mine has held charge and taken charge from the alternator since.
PostPosted: Tue Jan 22, 2013 5:29 pm
Thats why I use the 6 volt method as it takes much less time and does not trip the internal overload.
