| Rev just wondering http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=14158 |
| Author: | duneman [ Wed Oct 03, 2012 8:03 pm ] |
| Post subject: | Rev just wondering |
what would be considered "too high" of an rpm to be reving my vw at. what would be considered hurting it? |
| Author: | MickeyMouse [ Wed Oct 03, 2012 8:09 pm ] |
| Post subject: | Re: Rev just wondering |
What are some details on your engine? For my engine, a built up 2276, I run a rev limiter at 6000RPM, |
| Author: | JeffClay [ Wed Oct 03, 2012 8:12 pm ] |
Cam, rockers, pushrods, valve springs, etc. etc. all play a role in this. I remember a stock single port motor that Kyle Martin had SCREAMING at 4,000. |
| Author: | bige70chevy [ Wed Oct 03, 2012 8:48 pm ] |
my redline is at 6000 had to take it to 6500 last saturday night...if you runnin anything close to stock id stay at 5000 |
| Author: | dink2275 [ Wed Oct 03, 2012 9:25 pm ] |
it will stop its self just keep it on the floor till you get to the top |
| Author: | Red Barron [ Wed Oct 03, 2012 11:25 pm ] |
Great answer Dink, I always use to let it eat, what do you need a tach for? Thats what rev limiters are for. |
| Author: | duneman [ Thu Oct 04, 2012 11:12 am ] |
I have know idea if it has a rev limiter on it. I if it does I have never hit it. 2350 Webber 44. Not sure about the push rods and what not though. I believe the highest I have gotten it up to was 5000 rpm. |
| Author: | Rick [ Thu Oct 04, 2012 11:25 am ] |
duneman wrote: I have know idea if it has a rev limiter on it. I if it does I have never hit it. 2350 Webber 44. Not sure about the push rods and what not though. I believe the highest I have gotten it up to was 5000 rpm. how did you come up with 2350? |
| Author: | kyjr.buggy1 [ Thu Oct 04, 2012 11:46 am ] |
duneman wrote: I have know idea if it has a rev limiter on it.. Well does it have an MSD ignition box or not ? If so, which one? And yea, what's a 2350? |
| Author: | Red Barron [ Thu Oct 04, 2012 1:07 pm ] |
If you do have stroked engine it will not tolerate RPM in excess of 6,000 without serious balancing and blueprinting. If all internals (rod assembly, pistons) are gram-ed out to 1/10 of an gram then higher rev limits are possible. Most rod sets are matched meaning they are within an acceptable range. Piston sets are the same. By weighing them and by shaving/ polishing off material in areas that do not compromise the part until each piece is within a tenth of a gram.The entire rotating assembly can be balanced together following the gram-ing of the rod assemblies and pistons. This level of balancing will produce the greatest potential for a smooth running high revving engine. |
| Author: | duneman [ Fri Oct 05, 2012 11:48 am ] |
So basically just play it safe and not go over 5k? |
| Author: | Roy [ Sat Oct 06, 2012 7:24 am ] |
5000 is a good number to keep it at. You are really not gaining much anyhow by taking it to 6000. The lower you keep it the longer between engine overhauls. |
| Author: | 2800passat [ Sat Oct 06, 2012 10:58 am ] |
just tape a picture of your kids to your steering wheel as a rev limiter. |
| Author: | Money520 [ Mon Oct 08, 2012 7:34 pm ] |
i had a motor guy tell me if you cant climb it at 5500 rpms you cant climb at 6000. i dont know if its true or not ive been asking myself the same question on where to set the msd box at on mine. |
