 Post subject: Need help
PostPosted: Wed Jul 25, 2012 11:43 pm
I flipped my buggy and broke the mount where the trailing arm pivots by the trans. Got a new bracket but don't know how important it is to have it welded back perfect in the same place, any suggestions on how to get it close or perfect???
 Post subject: Re: Need help
PostPosted: Thu Jul 26, 2012 3:40 am
call joe he cut mine out and put in a whole new one
PostPosted: Thu Jul 26, 2012 8:00 am
If it was me I would measure side distances and then take a degree finder and c what the good side is at then set the new one at that degree and then tack it . Then ck measurement again and test fit arm . If all good blaze it in .
Hope this helps some .
PostPosted: Thu Jul 26, 2012 10:04 am
Sounds easy enough, thanks that's what I'll do
PostPosted: Thu Jul 26, 2012 11:19 am
just finished doing the same thing to mine. did just like giveitagallon said and all worked out well
PostPosted: Thu Jul 26, 2012 2:55 pm
They also sell gigs or you can make one. Google search "irs pivot jig".
PostPosted: Thu Jul 26, 2012 6:27 pm
Call keith mitchell he has a pivot jig he will let you use im sure. We used to build a custom torsion and it worked perfect.
PostPosted: Thu Jul 26, 2012 7:16 pm
I'll ask him. He should
PostPosted: Thu Jul 26, 2012 8:50 pm
Never new they made one , good call !
PostPosted: Thu Jul 26, 2012 11:56 pm
here is a pic of one in use
http://www.pacificcustoms.com/AC000155.html
