It is currently Sun May 03, 2026 10:33 pm
 Post subject: power pulley
PostPosted: Tue Oct 02, 2007 11:22 am
I have a power pulley that started leaking oil the problem is that it rides so close to the pump Im having a hard time finding a pully that fits,it has 4 shims behind it to space pulley out but not enough for any other pulley does any body have any advice?
PostPosted: Tue Oct 02, 2007 11:40 am
Have you considered a BMD serpentine pulley? I think they are the best pulley systems around. They come with all the hardware need for easy install. Check this guy out, his name on here is Turboblue (Gary) www.davisracing.com Very knowledgeable and he sells BMD's. You also might want to take into consideration that useing that many shims, the contact area of the crank and pulley is minimal and these pulleys will take care of that problem. Talk to Turboblue and see what he suggests.
PostPosted: Tue Oct 02, 2007 4:03 pm
we all ways just grind a littel off the back of the pully and a littel off the front of the oil pump
PostPosted: Tue Oct 02, 2007 8:12 pm
Thanks for the input this helps out alot,I think ill try the easy cheap way first and do a little grinding see what happens.
PostPosted: Tue Oct 02, 2007 8:26 pm
If you go that route try to find someone with a lathe or take it to a machine shop and have it cut. If you grind too much off of one side you will offset the balance of the motor and wear out bearings faster than you want. It might be better to pay a couple bucks now than replace bearings later. Good luck!
PostPosted: Wed Oct 03, 2007 8:00 pm
Are you sure your seal is not stuck to you pulley and is spinning in the housing? Most of the time you need to J B weld it in.Just a thought.MIKE
PostPosted: Sun Oct 07, 2007 6:06 am
I bought a BMD pulley and I still have all my old stuff. I will sell it cheap. Small pulley clearanced + with a good seal.
PostPosted: Mon Oct 08, 2007 8:44 pm
Hey Roy what do you want for your pulley
PostPosted: Wed Oct 10, 2007 4:14 am
PM me and we can discuss.
