It is currently Tue May 05, 2026 2:34 am
PostPosted: Fri Jun 01, 2012 9:32 am
I've beensearching the net with no success for some actual measurements on Warrior beams. They're sold in lengths of +6", +8" etc over stock length, but what does that work out to be for a total length? The same can be said about the shock towers, they give an additional inch value over stock length.
I'm not sure what my beam is, but I'm roughly 39 1/4" on the upper tube outside to outside, and 15" high from the top of the top tube to center on the upper shock mount. Any help is appreciated, thanks in advance!
PostPosted: Fri Jun 01, 2012 9:47 am
The widest part of my stock beam measures 34". And 15" from the shock bolt to the bottom.
PostPosted: Fri Jun 01, 2012 9:49 am
Call Roy and ask :lol: :lol:
PostPosted: Fri Jun 01, 2012 10:00 am
15" from the shock bolt to the bottom of the lower tube?
PostPosted: Fri Jun 01, 2012 10:12 am
Yeppers!
PostPosted: Fri Jun 01, 2012 4:59 pm
I have a 6 " over Ching Chonganese warrior beam on my buggy and it is 40 " wide tube end to end and the shock towers are 12" from top of top tube to center of the top shock bolt
PostPosted: Fri Jun 01, 2012 9:10 pm
dont be scared!!!! lol :mrgreen: :shock:
cron
