Welding issue
http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=13546
Author:  giveitagallon [ Sat Apr 21, 2012 9:31 am ]
Post subject:  Welding issue
I am using a miller mig welder and I am having a problem with air pockets coming to the surface when I weld . I am not a great welder for one but after I changed the wire spool it started to do this . I there such thing as getting a bad spool of wire ?
Author:  gasman [ Sat Apr 21, 2012 9:40 am ]
Post subject:  Re: Welding issue
I've heard a few people say certain wire in certain machines work better or worse. Chad :mrgreen:
Author:  Crambo [ Sat Apr 21, 2012 9:57 am ]
Bought some wire that had been laying out once and it had some residue on it, i bought some of those fiber pads you clip on and it wipes it as it spools off. If your metal has some oil on it it can also cause it to bouble like that, or out of welding gas can cause it unless you welder is gasless. I've also grab the wrong wire before, like flux cored for a gasless.
Author:  giveitagallon [ Sat Apr 21, 2012 10:49 am ]
Was just talking with russ on things to ck and as I was putting a new spool on it I noticed a two foot long peice of wire from the the last spool had broken off inside of the lead . Which was binding the wire and probly causing a inconsistent gas pressure to the tip .
I bought 035 wire this time but the machine came with 030 so I'm going to go get a roll of 30 and try it out .
Hope it works !
Thanks guys for your input !!!!
Jason
Author:  dirtdobber [ Sat Apr 21, 2012 1:53 pm ]
If you use.35 wire, you need to change copper tip on gun . That's what I use. Copper tips just screw in. They will say .35 or.30 on side.
Author:  Russ-the-Buss [ Sat Apr 21, 2012 3:08 pm ]
Flux core wire will cause more splatter causing the slag bubbles your talking about,to clean your weld up, go to non flux with gas..the diff. is amazing..also. sounds like you need to slow your roll if that makes sence.i have found that slowing down a lil improves my bead alot and i always feel like im going to slow to begin with.. :shock: ..just sayin
Author:  Pak Rat 2056 [ Sat Apr 21, 2012 6:18 pm ]
TURN THE GAS ON
Author:  nitro_mudder [ Sat Apr 21, 2012 6:41 pm ]
He had an old piece of wire get stuck in from the last spool. It was blocking the gas, all fixed.
