| will it back off? http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=13254 |
| Author: | jon williams [ Sun Feb 26, 2012 6:47 pm ] |
| Post subject: | will it back off? |
Put on my new chromoly spindles. (EMPI) but both spindles are threaded left hand. (Passenger side is wrong) will the nut back off? It has an Alan head set screw. Opinions please. Thanks. |
| Author: | ridenrace6 [ Sun Feb 26, 2012 7:06 pm ] |
| Post subject: | Re: will it back off? |
i had one that somebody had welded a passenger spud on the drivers side and it never came off but it would nould get a little loosen up a little from time to time and it had the clamp style nuts also |
| Author: | jon williams [ Sun Feb 26, 2012 7:25 pm ] |
Just don't want my wheel flying off on a hill |
| Author: | kevin f [ Sun Feb 26, 2012 7:46 pm ] |
front wheels are over rated anyway. But for real it will be fine just lock the spindle nut down tight. |
| Author: | MadMike [ Sun Feb 26, 2012 8:34 pm ] |
kevin f wrote: front wheels are over rated anyway. But for real it will be fine just lock the spindle nut down tight. I wouldn't over tighten it, hows about double nut or one of them aluminum nuts with a cross bolt. |
| Author: | jon williams [ Sun Feb 26, 2012 9:01 pm ] |
I'm running the aluminum nuts with the set screws. Guess I can buy another left hand thread nut and be done. But figured they were different for a reason. If some of you guys would just run it like it is let me know. Just wanted input to see if any of you have ran into this. |
| Author: | MadMike [ Sun Feb 26, 2012 9:06 pm ] |
I will say this again EMPI=JUNK |
| Author: | MadMike [ Sun Feb 26, 2012 9:21 pm ] |
The other thing I will add is I have more chromolly splinters in my fingers and hands than those spindles do. It's amazing on how much stuff is made from chromolly when it's all 1018 or 1020. And when someone says "made from 300M", you better have a spec sheet to show me, ever try to by the stuff? |
| Author: | jon williams [ Sun Feb 26, 2012 9:31 pm ] |
MadMike wrote: I will say this again EMPI=JUNK I like the quality of the parts I just think they were miss built. I can prolly call them and they will send me another spindle but if I can run it like it is safely I will. And yes I agree for the most part with some of their parts, the quality is not there in some instances |
| Author: | ron [ Fri Mar 02, 2012 4:18 pm ] |
MadMike wrote: I will say this again EMPI=JUNK JUNK A'INT THE WORD !!!!!!!! |
| Author: | 3drinkminimum [ Fri Mar 02, 2012 5:55 pm ] |
EMPI=JUNK |
| Author: | nitro_mudder [ Fri Mar 02, 2012 9:11 pm ] |
If they built it right the first time they would only sell it once |
| Author: | jesse [ Fri Mar 02, 2012 10:29 pm ] |
if it falls off we will just put it back on |
| Author: | 2800passat [ Fri Mar 16, 2012 12:46 am ] |
MadMike wrote: I will say this again EMPI=JUNK All California crap is junk or made in China.I learned that 20 years ago when my friends crank would explode and destroy block rods cam leaving nothing but heads and a carburator behind. That is why I desperatly build out of the junk yard.Quit making them millionaires. |
