It is currently Mon May 04, 2026 7:39 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jan 11, 2012 11:40 pm
1) All Park Rules will be strictly enforced and supersede any Woodsbuggy rules.
2) All Timer Failures will be an automatic re-run for that competitor.
3) Bolted tires are allowed unless park rules prohibit bolted tires.
4) All drivers must register and pay a $25 entry fee for each event.
5) All rules and regulations apply equally to all 2 wheel drive vehicles and all 4 wheel drive vehicles , however only 2wd activated and all entries will have engine behind driver .
6) For any given event, One buggy per driver and one driver per buggy with the exception of a rookie driver or family member.
7) No passengers allowed with the exception of a parent for a rookie driver.
8 All vehicles must pass a Technical Inspection before the races begin.
-Full tube frame
-open front wheels
- Min of 15 inch wheels
- Min of a 86 wheel base
-Min. 64 inch track width
- 4 or 5 point harness
- At least 6 points connecting roll cage to frame (using tubing no less than 1.25 inches in diameter)
- Secure Battery and Fuel Tank
9) DOT approved helmets are mandatory for every driver and must be properly fastened.
10) All drivers must sign a WoodsBuggy waiver in addition to any park waivers.
11) All drivers must attend the drivers meeting before the race for each event.
1) Competitors will draw numbers to determine the order for qualifying.
2) Each competitor will complete 1 qualifying run.
3) If the 1st qualifying run is a DNF or a Timer Failure, the competitor will be offered a 2nd qualifying run.
4) Based on qualifying times, drivers will be divided into 3 classes :
*** 45% of the buggies will be in the A Class, in event of fraction round up
*** 33% of the buggies will be in the B Class but figure A and C first then remaining go here.
*** 22% of the buggies will be in the C Class, in event of fraction round up.
5) Competitors will have the option to pay an additional $5 to move up to any another Class.
6) Additional $5 upgrade fees will be applied to the Total Payout at the current event.
7) Qualifying time will determine the race order... slowest to fastest... slowest time will run first.
8) Qualifying time for B Class and C Class will be Averaged with best Race Time to determine the winner.
The payout will be divided between all three classes
Class A
1st Place - 20% of the total payout
2nd Place - 17% of the total payout
3rd Place - 15% of the total payout
Class B
1st Place - 13% of the total payout
2nd Place - 11% of the total payout
3rd Place - 9% of the total payout
Class C
1st Place - 7% of the total payout
2nd Place - 5% of the total payout
3rd Place - 3% of the total payout
PostPosted: Wed Jan 11, 2012 11:43 pm
I proofread best I could but I may have missed something,,therefore we reserve the right to make corrections. I know some will disagree with these rules but they were discussed heavily with a dozen committee members and I think they deserve gratitude rather than quarrel. thanks and see you in the woods.,,,Oh and the dates will follow soon.
PostPosted: Thu Jan 12, 2012 2:14 am
Can u run 14" front wheels?
PostPosted: Thu Jan 12, 2012 2:20 am
they sound good marty im actually gonna get in the bama event for once lol but any word on the hill layout as to if theirs just one or more and do they have to be a fresh cut hill the day before
PostPosted: Thu Jan 12, 2012 3:59 am
I'd say those are the most legit sounding set of rules to date....
PostPosted: Thu Jan 12, 2012 7:13 am
A wheel is a wheel is a wheel,,,you can run a 14 inch steering wheel :roll:
PostPosted: Thu Jan 12, 2012 7:30 am
Well I guess we will be competing with sxs's.good luck to everyone and may all be safe and have a great year.Chad :mrgreen:
PostPosted: Thu Jan 12, 2012 8:16 am
Looks good guys. Dont see 4x4's or sxs's competing in 2wd, so dont worry about a ton of rzrs or Mark. Qualifying runs not averaged in in B-class, just C-Class? Best full set of rules yet. Need to make sure we post these tech specs on the fliers, small print should do.
PostPosted: Thu Jan 12, 2012 8:19 am
good question,, I better check,,,,
PostPosted: Thu Jan 12, 2012 8:22 am
corrected this,,,sorry
PostPosted: Thu Jan 12, 2012 8:48 am
So what you are saying is no 4x4 buggy's :?:
PostPosted: Thu Jan 12, 2012 10:35 am
read rule #5 REAL CLOSE again a couple times , you coming to the bama event !!! :wink:
you got it now !!! :wink:
PostPosted: Thu Jan 12, 2012 10:43 am
we usually have 3 hills a , b , c , & ours at bama will be on fresh dirt , thats usually at every event !! :wink:
PostPosted: Thu Jan 12, 2012 11:41 am
I must not be reading something right.I read it as all 4x4's can enter.rzrs xp 900 is about 5" short on the wheel base but the stock 4seater with rims and tires would be legal.so why would they run it in 2wdthen that would just eliminate them,they are legal to run 4wd.and the 64"min width and86"wheel base is to accomidate somebody because there isn't a buggy out there that short or narrow.so alot of sxs's will not qualify so this might limit the entries.so if you fixed it to allow one or two certain people in then you should.
Have dropped the wheel base 5" and just allowed them all in.chad :mrgreen:
PostPosted: Thu Jan 12, 2012 11:47 am
rea d rule 5 again , only 2 wheel drive activated buggies , front wheels cannot be pulling !!!
PostPosted: Thu Jan 12, 2012 2:27 pm
IThanks Ron, I was reading it as if you run 2wd, vehicles had to be mid or rear engine.never said I wasn't a dumb ass from time to time,lol.chad :mrgreen:
PostPosted: Thu Jan 12, 2012 3:05 pm
WB Competitor
it all looks good to me.
PostPosted: Thu Jan 12, 2012 5:27 pm
And as far as the length, it is because we have a few guys running that length and a buch running 90" at Haspin here in Indiana. And they run strokers in em too. It is very tight on alot of what we ride and my 103" has trouble making the turns as fast as the short buggies do.
PostPosted: Thu Jan 12, 2012 6:52 pm
Really 86" buggies,that's short.that's shorter than a stock VW.them be some good wheelie riders,lol.Chad :mrgreen:
PostPosted: Thu Jan 12, 2012 7:24 pm
With all the power steering and stuff they do ok, nice and heavy.
PostPosted: Thu Jan 12, 2012 7:26 pm
these rules are outrageous my woodsbuggy aka my grandfathers wheel chair wont qualify :twisted: :twisted: :mrgreen:
PostPosted: Thu Jan 12, 2012 8:55 pm
My granddads did. We just extended it 10 ft and put 15 inch spinners all the way around it. Now the motors not big enough :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Thu Jan 12, 2012 9:00 pm
Quote:
jesse wrote:these rules are outrageous my woodsbuggy aka my grandfathers wheel chair wont qualify :twisted: :twisted: :mrgreen:
:lol: :lol: :lol: time to add some power to the jazzy :mrgreen:
PostPosted: Thu Jan 12, 2012 11:42 pm
so i guess we wont be seeing mark this year
PostPosted: Fri Jan 13, 2012 11:44 am
Mark might show, but wont be able to compete. At least not very well.
