 Post subject: tubing question
PostPosted: Sun Dec 04, 2011 11:54 pm
just wanting to get a idea of the weight difference between 120dom and 83 wall seemed tubing per foot thanks
 Post subject: Re: tubing question
PostPosted: Mon Dec 05, 2011 12:17 am
1.50 0.120 dom 1.769 lb/ft
1.50 0.85 tubing 1.256 lb/ft
PostPosted: Mon Dec 05, 2011 12:47 am
got this off of pirate, im sure the prices are off but the strenght and weight is whats important
Chrome-Moly Tensile Strength = 90,000 psi
Dia. (in) Thickness (in) ID (in) Cross Sect. Area (in^2) Tensile Strength (lbs) Cost ($/ft) Weight (lb/ft)
1.75 ---- 0.120 ---- 1.51 ---- 0.61 ---- 55,303 ---- $6.63 ---- 2.089 lb
1.75 ---- 0.095 ---- 1.56 ---- 0.49 ---- 44,453 ---- $6.59 ---- 1.679 lb
1.75 ---- 0.083 ---- 1.58 ---- 0.43 ---- 39,119 ---- $8.17 ---- 1.478 lb
1.50 ---- 0.120 ---- 1.26 ---- 0.52 ---- 46,821 ---- $6.01 ---- 1.769 lb
1.50 ---- 0.095 ---- 1.31 ---- 0.42 ---- 37,738 ---- $5.74 ---- 1.426 lb
1.50 ---- 0.083 ---- 1.33 ---- 0.37 ---- 33,253 ---- $5.51 ---- 1.256 lb
1.25 ---- 0.120 ---- 1.01 ---- 0.43 ---- 38,339 ---- $5.65 ---- 1.448 lb
1.25 ---- 0.095 ---- 1.06 ---- 0.34 ---- 31,023 ---- $5.44 ---- 1.172 lb
1.25 ---- 0.083 ---- 1.08 ---- 0.30 ---- 27,386 ---- $5.50 ---- 1.034 lb
1.00 ---- 0.120 ---- 0.76 ---- 0.33 ---- 29,857 ---- $5.54 ---- 1.128 lb
1.00 ---- 0.095 ---- 0.81 ---- 0.27 ---- 24,308 ---- $5.42 ---- .9182 lb
1.00 ---- 0.083 ---- 0.83 ---- 0.24 ---- 21,519 ---- $5.39 ---- .8129 lb
1.00 ---- 0.065 ---- 0.87 ---- 0.19 ---- 17,183 ---- $4.98 ---- .6491 lb
DOM Tensile Strength = 70,000 psi
1.75 ---- 0.125 ---- 1.50 ---- 0.64 ---- 44,668 ---- $5.54 ---- 2.169 lb
1.75 ---- 0.095 ---- 1.56 ---- 0.49 ---- 34,575 ---- $5.36 ---- 1.596 lb
1.75 ---- 0.083 ---- 1.58 ---- 0.43 ---- 30,426 ---- $5.23 ---- 1.478 lb
1.50 ---- 0.120 ---- 1.26 ---- 0.52 ---- 36,416 ---- $5.18 ---- 1.769 lb
1.50 ---- 0.095 ---- 1.31 ---- 0.42 ---- 29,352 ---- $5.92 ---- 1.426 lb
1.50 ---- 0.083 ---- 1.33 ---- 0.37 ---- 25,863 ---- $5.61 ---- 1.256 lb
1.25 ---- 0.120 ---- 1.01 ---- 0.43 ---- 29,819 ---- $5.28 ---- 1.448 lb
1.25 ---- 0.095 ---- 1.06 ---- 0.34 ---- 24,129 ---- $5.00 ---- 1.172 lb
1.25 ---- 0.083 ---- 1.08 ---- 0.30 ---- 21,300 ---- $5.57 ---- 1.034 lb
1.00 ---- 0.120 ---- 0.76 ---- 0.33 ---- 23,222 ---- $5.00 ---- 1.128 lb
1.00 ---- 0.095 ---- 0.81 ---- 0.27 ---- 18,906 ---- $5.00 ---- .9182 lb
1.00 ---- 0.083 ---- 0.83 ---- 0.24 ---- 16,737 ---- $5.00 ---- .8129 lb
1.00 ---- 0.065 ---- 0.87 ---- 0.19 ---- 13,365 ---- $5.00 ---- .6490 lb
HREW Tensile Strength = 40,000 psi
1.75 ---- 0.120 ---- 1.51 ---- 0.61 ---- 24,579 ---- $5.20 ---- 2.089 lb
1.75 ---- 0.095 ---- 1.56 ---- 0.49 ---- 19,757 ---- $5.06 ---- 1.596 lb
1.75 ---- 0.083 ---- 1.58 ---- 0.43 ---- 17,386 ---- $5.11 ---- 1.478 lb
1.50 ---- 0.120 ---- 1.26 ---- 0.52 ---- 20,809 ---- $5.16 ---- 1.769 lb
1.50 ---- 0.095 ---- 1.31 ---- 0.42 ---- 16,772 ---- $5.00 ---- 1.426 lb
1.50 ---- 0.083 ---- 1.33 ---- 0.37 ---- 14,779 ---- $5.00 ---- 1.256 lb
1.25 ---- 0.120 ---- 1.01 ---- 0.43 ---- 17,039 ---- $5.04 ---- 1.448 lb
1.25 ---- 0.095 ---- 1.06 ---- 0.34 ---- 13,788 ---- $5.00 ---- 1.172 lb
1.25 ---- 0.083 ---- 1.08 ---- 0.30 ---- 12,172 ---- $5.00 ---- 1.034 lb
1.00 ---- 0.120 ---- 0.76 ---- 0.33 ---- 13,270 ---- $5.00 ---- 1.128 lb
1.00 ---- 0.095 ---- 0.81 ---- 0.27 ---- 10,804 ---- $5.00 ---- .9182 lb
1.00 ---- 0.083 ---- 0.83 ---- 0.24 ---- 9,564 ---- $5.00 ---- .8129 lb
1.00 ---- 0.065 ---- 0.87 ---- 0.19 ---- 7,637 ---- $5.00 ---- .6490 lb
http://www.pirate4x4.com/forum/showthread.php?t=216233
PostPosted: Mon Dec 05, 2011 9:15 pm
thanks for the info
