 Post subject: Air filter.
PostPosted: Sun Dec 04, 2011 4:23 pm
I saw a link on here a while ago for a different style air cleaner adapter for the webber 44 style carb. dies anyone know here i can order one?It is the adapter that goes from the square style to a more of a dish style.
 Post subject: Re: Air filter.
PostPosted: Mon Dec 05, 2011 2:00 am
is this whar you are talking about
http://www.cbperformance.com/catalog.asp?ProductID=563
PostPosted: Mon Dec 05, 2011 9:22 am
I believe southern buggies are making some carb hats that were custom made ck with them they are also one of the sites sponsors .
PostPosted: Mon Dec 05, 2011 5:25 pm
ridenrace6 wrote:
Yes that's it thanks
PostPosted: Mon Dec 05, 2011 6:20 pm
if u can get them to run on ur motor good luck,,,i know alot of people that tried them on big motors and they will not suck enough air,,,i got a whole set i will sell u too
PostPosted: Mon Dec 05, 2011 9:56 pm
Yeah i was just going to say i revoke my last comment. I don't think it you'd be a good idea to change the height of my velocity stacks. And yes i do have a decently bored motor. what kind of setup do you have? i need something. i am cleaning out my idl jets almost every ride.
PostPosted: Mon Dec 05, 2011 10:57 pm
do you have the jet doctor tubes on the carb? i have a single weber 40 , that i bought from weber and it didnt come with them or the velocity stacks, aparently a must have!! i had quite a few problems out of mine till i put all that on. heres the link in case you need ithttp://www.cbperformance.com/catalog. ... uctID=1507
PostPosted: Mon Dec 05, 2011 11:09 pm
This is how I did mine. Best thing I've done. Haven’t had to clean a jet since the install. I think the total cost was like $50-$60. I haven’t even changed the filter since I put it in.
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=3&t=6063&st=0&sk=t&sd=a&hilit=industrial+air
PostPosted: Tue Dec 06, 2011 6:54 pm
i got jet doctors on mine and good k & N filters and i pu wheel bearing grease on top and bottom of filter so no dirt will go between the base and the filter,,and never a problem with idle jets
PostPosted: Wed Dec 07, 2011 10:08 pm
Thanks. i mite just have to do this. Where did you get that shroud that converts from the carb to the hose fitting?
PostPosted: Wed Dec 07, 2011 10:11 pm
this a defiant get. thanks for the link. and its cheep to.
