It is currently Mon May 04, 2026 12:02 pm
PostPosted: Sat Aug 20, 2011 2:50 pm
just wondering if anyone has flipped the diff in a bus trans :?: I'm pulling the honda motor out of my baja bug to put in a buggy but I don"t want to run the car trans thats in the bug. can this be done :?:
PostPosted: Sat Aug 20, 2011 5:00 pm
leave the baja together and sell it!!!!!!!! :mrgreen:
PostPosted: Sat Aug 20, 2011 8:43 pm
You cannot flip the diff in a bus trans. Only way to make it work with a reverse rotation engine is to mount it in the chassis upside down and that takes alot of internal modifications. I wasn't aware there were any reverse rotating engines in cars these days. And to think I work on this junk every day!
PostPosted: Sat Aug 20, 2011 10:17 pm
If you have a Honda eng, do like passat.Or jump off a cliff and be done with it.
PostPosted: Sun Aug 21, 2011 4:30 am
LMFAO. !!!!!!!!
PostPosted: Sun Aug 21, 2011 1:25 pm
yeah I have heard of mounting them upside down but thats just silly..dont corvairs spin backwards I"ve seen those mated to a 6 rib.....not sure how they did it
PostPosted: Sun Aug 21, 2011 1:45 pm
All the corvair engines I have ever seen in buggies had the camshaft swapped out to run standard clockwise rotation
PostPosted: Mon Aug 22, 2011 5:01 am
There is a buggy out there that is running a 3.0 Honda v-6 engine.....it is bolted up to a 6-rib tranny and his name is Mike Picard I think, his buggy has been to many places.....most of us should have seen his buggy on here before.
PostPosted: Mon Aug 22, 2011 11:04 am
What about a 1.6 Passat gearbox? (about year 2000)
PostPosted: Mon Aug 22, 2011 2:37 pm
ask trailrider, look under buggys builds got honda
PostPosted: Mon Aug 22, 2011 5:40 pm
the honda motor that i have spins in the right direction for the VW trans. I also run Corvair and they spin backwards. they make a reverse cam for the corvair so that it will spin the right direction. alot of guys with the corvair use to flip the ring gear in the trans so that it would spin the right way, but the ring gear will not hold up when you do that.
Users browsing this forum: No registered users and 5 guests
